- Aug 18, 2011
- 12,485
- 18,875
- AUTOSLEEPER SYMBOL
- since 2007.Tugger before since 1970
Morning Dave
It wasn't weight capacity but weight distribution that surprised me. I was surprised how far rearwards I'm having to put the same load to retain a good weight balance front to rear when the van is only 40cm longer than the previous one.
Not sure how much the OP has thought about balance when planning the layout but assuming the new empty van is riding level at the moment it is easy to get the proportions of front to rear axle weights at the beginning by weighing each axle separately. On top of which all these vehicles have the maximum front and rear axle loads shown under the bonnet so it's easy enough to check as the build progresses that one end or the other the maximum weight per axle is not being exceeded.
Its harder still when you have to load a van for multi drop deliveries when each item is a different weight and size and you have to load it in a delivery order..Many panel vans must be overloaded .BUSBY.
