- Sep 21, 2022
- 29
- 6
- Hobby Siesta Exclusi
- I’m a newbie
Very useful thank youThere is no requirement for you to weight your MH when going to Europe (mainland) so I'm not sure where that's come from. It may be something to do with speeds but would be more applicable to the UK rather the Europe as UK speed limits are based on a vehicle's unladen weight whereas abroad they are based on MTPLM - don't worry about it though for your situation.
As for emptying it before weighing, that isn't a good idea as you would have to put back everything you want to take with you, including dogs, passengers, water etc and try to work out how much this things add which will affect the load on each axle depending on where they are and it wouldn't be as accurate (even using the spreadsheet above) as weighing it fully laden. It's much better therefore to load it up as if you were actually going away in it so it is in full holiday trim with you, passengers, dogs etc, basically everything that will be travelling in it and then get it weighed. You need either both axles weights or and overall weight an one axle weight as you can work out the overall and/or individual axle weights from this. It is possible to be within the overall weight but over on one of the axles (usually rear) and this is where some who only use an overall weight figure come unstuck ... you can tell who they are as the MH rear is nearly dragging on the floor!
You’re right about it being applicable to U.K. Up to 3050kgs unladen weight, the speed limit on single carriageway roads is 60mph (same as a car).. Over 3050kgs unladen weight it’s 50mph, same as a panel van.There is no requirement for you to weight your MH when going to Europe (mainland) so I'm not sure where that's come from. It may be something to do with speeds but would be more applicable to the UK rather the Europe as UK speed limits are based on a vehicle's unladen weight whereas abroad they are based on MTPLM - don't worry about it though for your situation.
Yep, up in Eastleigh at Aggregate Industries (Aggregates), right at the end of Tower Lane off Chicken Hall lane, here ... If the link's worked and you put the satellite view on the weighbridge is right under the location pin. Unless it's changed, call their Portsmouth base where you can book and pay, on 02392 662801Does anyone know of a weighbridge in / near Southampton that I can get my Burstner Nexxo , (6.2m) weighed?
Under the bonnet is where mine is.Cheers Verteuil (Local) Man, any idea where I may find such a plate on my vehicle?
Whether or not you can tow a trailer is dictated by the weights on the VIN plate. On most vehicles, that’s under the bonnet. Mine actually has 3! 1st was Fiat’s original, 2nd was Alko’s who modified the chassis and 3rd was Rapido. The final adapters plate is the relevant one. (For info, Hymer had a sticker near the habitation door on my first 2 Hymers).Ok........Silly Question time. If towing a trailer with a motorbike on it, does that affect the weight limit of the motorhome. I have been told it does, and been also told it doesn't..........is there a definitive answer?
Legislation on pharmacueticals dictates the information that has to be displayed.When I buy a packet of aspirins or a new tool there is a long list of do's and dont's, but it seems that there is no equivalent with a MH, specifically about weight and payload.
Why not?
Many thanks for the info. Will sort out after next week as booked into Back of Beyond site, just in time for the snow!Yep, up in Eastleigh at Aggregate Industries (Aggregates), right at the end of Tower Lane off Chicken Hall lane, here ... If the link's worked and you put the satellite view on the weighbridge is right under the location pin. Unless it's changed, call their Portsmouth base where you can book and pay, on 02392 662801
There will be two or three plates on your vehicle, The base vehicle plate, The chassis plate if it has an Al-Ko chassis & the converters plate. The last plate fitted supersedes all other plates which will be the converters plate & it could be anywhere, on the sill in the footwell, under the bonnet etc.Cheers Verteuil (Local) Man, any idea where I may find such a plate on my vehicle?
No it's not, on your Hymer it will be on the sill behind the RHS rear wheel.Under the bonnet is where mine is.
I've never tried to swallow a MH...When I buy a packet of aspirins or a new tool there is a long list of do's and dont's, but it seems that there is no equivalent with a MH, specifically about weight and payload.
Why not?
but you do get a manual with a car. You also get a specification list. The specifications on motorhomes are carefully hidden and are misleading.At the end of the day it is common sense and asking people who have more experience. You do not get a manual with a baby or a car.
I think a lot of experience at work will also help. I had a lot of experience driver vans and lorries and when I was supervising on motorway jobs I was doing 120,000 a year in a car.but you do get a manual with a car. You also get a specification list. The specifications on motorhomes are carefully hidden and are misleading.
Don’t go to the Aggregate Industry one in Eastleigh….it’s broken…has been for 2 months. Pity as they used to do mine for freeDoes anyone know of a weighbridge in / near Southampton that I can get my Burstner Nexxo , (6.2m) weighed?
That is the base vehicle plate which is irrelevant you need to find the converters plate.Vertuil Man, this is what I located under the bonnet. Do you know from this image, what the "train weight " is and if so, how to calculate it?
You should come to the east coast, we’ve got sun, sort of!Cheers Lenny,
Will take another look when it stops persisting it down.![]()
But that plate is irrelevant.your gross train weight is 6 tonnes.
Your towing limit is 2,500kgs.
your MGW is 3,500kgs
your axle weights (max) are 1850kgs (front) and 2,000kgs rear
unless modified by a converters plate!
Not if it’s the only one!But that plate is irrelevant.
I’m near The Wash, so about 3 1/2hrs?We are not too far from you.......Wensleydale.
