Oyster Vision I upgrade to Vision II
Finnbaruk
94 Fiat / Hymer B694
Hello, I just got a motorhome with an Oyster Vision I set up. How easy is it to use the manual tuning? If I upgrade to a Vision II control box, etc., will that provide us with auto-tuning for watching Sky in mainland Europe?
I appreciate any help you can provide.
Anthony OysterTech your expert advice would be welcomed. I really appreciate any help you can provide.
Good afternoon Finnbaruk
The Oyster Vision I systems can be upgraded using the Command centre bundle available to order from ourselves. The Vision I system uses a 15 pin main cable running from the roof unit down to the control box which can be affected by oxidisation or splayed terminals at either end so we always recommend cleaning both ends and checking the pins to make sure you have a suitable connection to the new electronics before installing so as to avoid any communication failures which could cause damage to the system. The upgrade is £460 inc VAT. We can ship this for an additional carriage cost or a booking to ourselves can be made for fitting which would be subject to an additional Labour charge.
If you would like further information then please give us a call on 01858575928.
