Overcab Window Crack (1 Viewer)
May 14, 2018
353
471
Lincolnshire, UK
Autograph 794-T
Caravan owner moved on to Motorhome
The overcab 'sunroof' has developed a crack near the hinge. It's a 2017 Autograph II. Been trying to find one on the internerd with no luck. Prima seems to come up blank (but I never can find anything on that god awful site). Anyone got any suggestions for sourcing one?
Jul 15, 2023
116
116
Lincoln, UK
Bailey 79-4T
Feb 2023
No sugestion on purchase as I would imagine quite exspensive££££, with it being on the edge could you get it repaired?
Dec 6, 2011
12,201
27,282
South Wales
Coach built Adria
That looks if it’s in the outer lip only , if so drill a small hole at the top of the crack to stop it getting worse.
Then you can look at a repair.
I would be avoiding a £2k bill 😳
stevewagner
2,005
4,558
Pevensey Bay
Yonks
You should be able to claim on your insurance if you have glass cover.
Sep 9, 2019
959
2,123
Runcorn
Autotrail Apache 632
Since Sept 2019
As above, drill a 2 or 3mm hole into the very end of the crack. This will prevent the crack from spreading. Use a Stanley knife down the crack a couple of times to create a slightly larger surface area for the glue to grip on to. Get a pot of pvc pipe weld or pipe cement from Screwfix (catalogue number 14295) and dab in neatly over the crack. Leave it to dry for several hours. Then using a piece of sandpaper or similar you can remove any excess glue.
Now you need to tackle the problem of why it cracked in the first place. It looks like there is a hinge at the leading edge of the panel, it’s very likely to have seized through lack of use and moisture ingress. Open the hatch as far as it will go, then from the INSIDE of the van spray the hinge with silicone spray (Screwfix catalogue number 436FE), leave for 10 minutes then work the window up and down a few times. Just had another look at the hinge, silicone spray from outside too, BUT DONT GET BIT ON THE BODYWORK/PLASIC PANELS as it will make cleaning it and treating with wax etc in the future turn into a real pain! Job jobbed!
Cheers!
Russ
Paul Wilkins
May 14, 2018
353
471
Lincolnshire, UK
Autograph 794-T
Cheers!
Russ
The whole thing is a bit of a design bodge from the start. Its well shonky.
I'm touring at the moment, will get a good look at it after next week when I get back to the UK.
Dec 6, 2011
12,201
27,282
South Wales
Coach built Adria
It would be good to get that crack stopped Asap with a small drill.
I would try and persuade someone to help do that before the crack crosses into the double glaze section, then you are really screwed.
Paul Wilkins
May 14, 2018
353
471
Lincolnshire, UK
Autograph 794-T
Do you know the German for 'Can you drill my sunroof at the end of the crack'? [Kannst du mein Schiebedach am Ende des Risses bohren?] and where to present ones self for such a request? It just isn't practical.
I've got the roof tied down so it wont move. It will just have to do.
Dec 6, 2011
12,201
27,282
South Wales
Coach built Adria
It’s not being tied down, it’s the wind under the leading edge could increase the crack.
I lived in Germany for a while and you will get help if you ask.
But many, many Germans speak enough English to help you.
I would find a small garage or diy place and see how inventive you can be.
It’s reparable at the moment.
But, at the end of the day it was only a suggestion, you may get home and it won’t be any worse, that’s the risk.
Jul 31, 2014
1,971
3,305
West Yorkshire
EuraMobil Activa 820HS
There’s a company near me called EECO in Elland, Halifax who specialise in repairing and selling replacement windows for caravans and Motorhomes.
I’d try them first before drilling your current window.
I’m sure if you can take some close up photos and explain the issue to them, they will advise you whether they can repair it and what they need? Ie, window taking off and sending or you driving to them etc.
Jul 31, 2014
1,971
3,305
West Yorkshire
May have moved to Shelf in Halifax if you google them
Oct 26, 2018
37
31
Burstner 680g Ixeo
Ownner for two years
Hi Paul, For such jobs I have used Bondic with excellent results. Even if you only use it until you find a new sunroof. I can recommend it for many other uses in the home or Motorhome.
Jun 14, 2014
1,631
3,546
Coventry
IH N680CFL
Since2014
I see the Northerners on tour have just done their last video replacing that window for the same reason.
Part was £800 I think but the place that fitted it might be helpful to call if you’re struggling to find one
Paul Wilkins
May 14, 2018
353
471
Lincolnshire, UK
Autograph 794-T
I tried them, unfortunately they don’t manufacture the curved overcab windows. I’m going to try SFM a try later.
Jul 31, 2014
1,971
3,305
West Yorkshire
That's a shame.
I think that SFM are a second hand caravan dealer, but they may know of someone to help.
Jul 31, 2014
1,971
3,305
West Yorkshire
Good advice but the op is currently in Germany touring
I thought he'd asked for advice on sourcing one, not repairing whilst currently in Germany " I'm touring at the moment, will get a good look at it after next week when I get back to the UK. " (post 8)
