- Oct 8, 2014
- 1,588
- 4,642
- Compactline 143
- I'm a newbie and always will be. You never know it all.
Does the heated barn have Alde as wellI will have you know that my new Swift has Alde heating dear boy!
You’ll have no problems with weight, our Hymer is 3035kg MIRO (supposed), a lot heavier than your Carthago. We have HPC jacks, rear air assist with compressor, Fiamma side awning, spare wheel, twin batteries, two large solar panels and two 11kg refillable gas bottles. With the two of us and the dog ready to go with clothes, supplies and water we weigh in at 3570kg, as verified by SV Tech at Peterborough Show. So we have 270kg spare with the rear axle at 1970kg.Don't think we'll have an issue with putting our stuff in!
Loads of A Class on the AMC light chassis, nearly all Hymer's up to 7.2 m available on it, latest versions have the even lighter SLC chassis.
The FWD Merc is 50 kg lighter than RWD but that is on a panel van.I'd beg to differ a bit on this. I would say the SLC chassis is remarkably light for a double floor of its width. But if I compare the weight of a B-MC T 580 (2900 kilos) to an ML-T 580 (2910 kgs), there is not much difference, which is surprising given the considerable weight of the rear transmission and the all steel, very utilitarian chassis of the ML-T. Of course, the ML-T is 7 cm narrower, which saves weight and that might account for the apparent paradox. On the other end, the furniture appears to me to be sturdier in the ML-T than the B-MC, but that's more a feeling than objective measurement.
But the end result, in terms of weight, is very close.
Hymer now use the SLC on Fiat as well they claim it is lighter.Then I think it is safe to say the SLC benefit is in having a double floor while keeping weight reasonable, but it is not lighter that a "normal" van.
Our 7.5m Hymer with all factory fit options we had is only 3340 kg.Wow it just shows how construction has changed, our little 2005 A class Concorde 6.48 metre, basic weight is not far off a tonne more than yours.
You missed the bit about me buying another Smart car then!Crickey, Mel, I'm off-line for 7-weeks and you go off and buy a 'Bubble Box' which has just enough payload to carry a million cubic feet of air.
You'll miss the Globecar and its heavy chassis for sure.
Have you got time to cancel the order.
You missed the bit about me buying another Smart car then!![]()
Noooooooooooooooooooooooooo ... you've got the wrong end of the stick ... we won't have a toad as the new Carthago is only 5 cms longer and 7cm wider than our Globecar, hence why we decided to change as we didn't want a much longer or fatter vehicle, therefore there's no need to tow anything.It gets worse Mel
An 'A-class with a toad' only means one thing, i.e. your OAP status is upon you.
You were the queen of modifications and coolness the other week and now..........let this be a valuable lesson to all of us Globecar owners: "old age is just an A-class away".
The 'new' Smart is a ForFour and for home pootling round only so as for old age ... its a Sports version with lowered suspension, bigger wheels and gear change paddles on the steering column so we can have even more fun with it, opposite of OAP status (ie old and creaky) ... brummm, brummm, BRUMMMMMMMM ... zzzzooooooooooooooooooooooooooooommmmm.
As for mods ... I'll still be doing some, just no need to do the basics such as fitting solar etc.
... you don't want to know about the Sym 125cc scooter we bought then ...A-class is Age-Class;
......and flappy paddles, lowered suspension and bigger wheels on a, errrrrrrrr, Smart Car; only an old person would be exited by that.
I'm going to 'case study' you Mel to ensure that I don't come to the same horrible end.
Poor Mel
Hab area |
Make/fit worktop flap, kitchen roll holder & tea/coffee/sugar rack |
Put up dog photo frame, coat hooks, clock, temp gauge, smoke & C0 alarm, fire extinguisher & blanket |
Protect table & put Fablon over glass hob/sink lids |
Make duck board for washroom floor & step for toilet |
Fit/make dog gate for hab door |
Line cupboard, drawers etc |
Fit rear window blind barrier |
Make laundry slot from hab into garage? |
Fit carpet/rugs (make cover/mat for large dash area?) |
Sewing |
Make/alter hab and cab seat covers & alter bedding |
Make roof vent covers |
Make external windscreen cover/alter existing |
Other |
Fit Gaslow cylinders & filler point |
Sort out garage storage/racking, bike fixings & secure spare wheel |
Put reflective tape on mirrors |
Fit extra stays to garage doors? |
Fit extra locks to lockers/doors? |
Fit 50w solar panel to roof or put in connector to use it as a portable one |
Fit 'gutter' above driver's side window |
Do list of where stuff is! |
I made on in our current PVC and it works an absolute treat and means it makes use of an otherwise difficult to access space in the rear. I'm not sure how/if I can put one in the new MH but will see what can be done when I get my grubby paws on it next week.I admire your detailed to-do list especially the laundry-shoot into the garage from the hab - very ingenious.
We're having an alarm fitted as part of the purchase deal, it's an Autowatch 695 with extra PIR sensor internally in the rear in case someone gets in via the back window, plus sensors on the 2 garage doors and the 2 lockers that would allow internal access (for a contortionist!).You mention the tracker system but no mention of an alarm system - is that an oversight or do you have that covered in other ways, like central locking integrated with an alarm ???
Nooooooo, don't have the PIR sensor, had one in the last van pain in the butt.We're having an alarm fitted as part of the purchase deal, it's an Autowatch 695 with extra PIR sensor internally in the rear in case someone gets in via the back window, plus sensors on the 2 garage doors and the 2 lockers that would al
On an A Class you rarely use the driver's door, only for fuel stops so don't really need central locking. We never have it, expensive option and you have to carry a bulky key around.There's no central locking on the new MH but as there are only 2 doors, and we'll likely mostly use the hab door its not a hardship. It does mean, however, that when we unlock a door it's ONLY that door that will be open,
We've got a PIR in our Globecar and have never had any issues with it at all, I suspect its partly down to positioning as to whether you'll have problems or not ... hopefully not!Nooooooo, don't have the PIR sensor, had one in the last van pain in the butt.
They set the alarm off if you leave the roof vents open when you go out also if you leave the heating on and when the battery goes flat in them.
Very unlikely anyone will get in the rear windows with the height of them.
Great news - GMC have just rung us to say they can't fit a single solar (150w or 140w) panel on the rear, only on the front which will cause wind noise issues so they've 'suggested' we have 2 x 100w on the rear instead ... which is exactly what we wanted in the first place!Solar: We can't have 2 x 100 panels due to supply/size issues so having 1 x 150w instead, should be sufficient for our needs but if not the controller they're putting on will take 300w so can add to it (I already have a 50w semi-flexible panel anyway so could stick that on).
I wouldn't risk if too much hassle if it plays up.We've got a PIR in our Globecar and have never had any issues with it at all, I suspect its partly down to positioning as to whether you'll have problems or not ... hopefully not!![]()
... it wouldn't DARE play up with me as it would get a swift kick!I wouldn't risk if too much hassle if it plays up.
... you don't want to know about the Sym 125cc scooter we bought then ...![]()
UPDATE ... again................
even though I was sure I was twiddling the knob correctly........ one of the chaps was nearby so we asked him about it .........He came over and had a look ............
What do you expect if you buy one with the steering wheel on the wrong side. Bet you haven't even got a driver's door.Carthagos are built mainly for the LHD market the UK passenger side door has a knob on for adjusting LHD drivers to adjust the mirrors with, which is the one I was using, but its just a dummy as they install one on the right for the UK driver to use - this meant that no amount of my twiddling with the knob was every going to get it to work!
Enjoy.
