suavecarve
I think it was to check the voltage of the battery from Victron when it was not being charged.I'm curious how the solar might be causing the problem?
Not causing a problem, just interfering with a test, as suavecarve says. If the hab battery voltage rises when the engine is running, it shows that the two big fuses, on the starter battery to PDU wire, and the PDU to hab battery wire, are both OK.I'm curious how the solar might be causing the problem?
Thanks, understoodNot causing a problem, just interfering with a test, as suavecarve says. If the hab battery voltage rises when the engine is running, it shows that the two big fuses, on the starter battery to PDU wire, and the PDU to hab battery wire, are both OK.
But if the solar is charging the hab battery, maybe directly and not through the PDU, then it will make the hab battery voltage rise. So you won't see a rise when the engine starts.
How strange our fluerette did exactly the same ,it will reset from the trauma panel,try pressing the button hard,worked for me straight away. Fault code if for heater..Hi All
Hopefully you can help!
We've borrowed a motorhome from a friend for a big trip to France and Spain. We're currently mid-way into the trip but our fridge, freezer, oven and water heater all seem to have lost power and won't turn on. We can live without the water heater and oven but getting the fridge/freezer back up and running while we're away would be really helpful. Especially as we have a 4 year old and 6 year old in tow.
It's a Fiat Ducato base van with a Fleurette Florium Mayflower build on the back.
The fridge/freezer/oven is a Dometic Rmdt 8505. The water heater is a Truma CP plus. It's got a Nordelettronica consumer unit [or whatever you call then in a MH]
I've read lots of threads on here about the fridge/freezer and it could well be a dead control panel but the fact the oven has also stopped working [it won't spark] and then water heater doesn't have a 12v supply [It's giving us the code W255 h] makes me think it might be something else.
I've put new brand new fuses in, I've checked the connections behind the fridge and I've had the control panel off the fridge to check that too. I've taken the cover off the consumer unit and checked all these connections too. All other electrics seem to be working fine.
It was working fine until we plugged into a campsite for the first time of the trip. And then I noticed the fridge was off [I can't even get the control panel to turn on on the fridge].
Does anyone have any ideas? Is there anything I've missed?
Thanks in advance!
