Newish van? How big is your gas locker
2016 Pilote 600L, 2 x 13 Autogas refillables and no room for anything else.
2018 Chausson 640 - Single 11kg.
2017 Knaus sun ti 650 mf 2 x 11kg gaslow current model same.
2018 Chic Eline 58XL. comfortably takes 2 gaslow 11kg or 2 calor 13kg
2010 Chausson Flash 04 - a single 11kg/13kg bottle.
2012 Autocruise Accent - supposed to take 2 x 6kg due to width of door aperture but with judicious use of a lump hammer I managed to 'squish' the base on our single 11kg Gaslow refillable and get it in!
2015 Globecar Familyscout L - it had a stupidly large gas locker which I put 2 x 11kg Gaslow refillables in without a problem but if I'd have the larger 14kg refillables they'd have gone in.
2018 Globecar Campscout - this had an even BIGGER gas locker and would easily have taken the same as the Familyscout and if they made 'chubbier' ones I'd probably have been able to get 2 x 20kg ones in!
2019 Carthago C-Compactline i-138 - similar size Campscout but with a bit more height so probably would take 2 x 14kg refillables; I've just put my 2 x 11kgs refillables in it.
2x 14kg and loads of junk stored in it.
Please for safety make sure the gas drop vents are clear and that any leaking gas can get past the 'junk' ... I don't like using plastic bags etc as they can allow gas to gather and sit in them rather than dissipate so if I do need to bag something I prefer netting/mesh bags.
Would hate to lose you Lenny! :*
All my vans were continental and they were 2 x13kgs, I now have an Autotrail Apache 700 and it is 1 x 13kgs and 1 x 6kgs
Ah, does this count?
Hobby 750 with underslung tank but used to be 2x13kg Calor and a load of junk.
It's big so they can fit the option slide out runners with a door in the side of the van
Ours has the separate door and slide out we have two 11KG Gasit refillables I would think we could get 14kgs in if we tried payload is really good on the B678DL ??
Good thing with the side door is you don’t have to unload the garage to get at the gas cylinders.?
Adria Matrix. Gaslow 2 x 11kg bottles (see attached image)
You sure, what you after?
I think you know me better than that, big vent at the back all the junk is in the front.
... and the plastic etc bags ... do they have any 'vents' in them?
2018 Carthago chic e -line
2 × 11kg Gaslow (fitting in a week or two)
6 metre Bolero 612 2x11kgs
Only just, at a very uncomfortable squeeze, is there room for 2 x 13kg calor in our Carthago. Hence the change to 11kg's
Burstner IXEO 720 A Class : 2x13kg bottles. No problems with payload as we are 4250kg
No gas locker whatsoever. The Autotrail V-Line has an underslung thing somewhere.
If garages stop selling LPG at the pump I'm in a whole heap of trouble as nowhere to revert to even a single normal cylinder.
2018 Burstner Harmony Line Ti 736. 2 x 13kg bottles fit in nicely.
These are 11kg
2017 Hymer Exsis-I578...... 2x13
Terry
2018 Dethleffs Globebus T7. 2 x 12.5 kg cylinders - each weighs around 26kg (12..5 kg gas + cylinder weight) so a total of 52kg plus fittings. Nb everyone seems to be just quoting the weight of the gas - not the actual weight of the gas + cylinder.
2016 Pilote G740C - 2 x 13kg soon to be replaced with 2 x 11kg gas it.
Brand new Chausson Welcome Premier 630 only Rooney for 1 x 11kg Gaslow bottle.
New Dethleffs Trend 6557 dbm. Currently two 6kg insitu. Looks like it would take two of larger size.
Are you gonna let him out? :D
