- Sep 28, 2015
- 2,291
- 3,183
- Hymer B544
- 2001 Caravans 2011 Motorhomes
Did you nip them up a little with a spanner?i just screwed them in and i did see a slight improvement
No but it's not moved, and they were tight when I undid them earlier but I can easily do thatDid you nip them up a little with a spanner?
which cables are in which port now? i will replicate it and see if mine shows improvementOnly had my X50 connected via a Poynting MIMO3 for a couple of months, only a few trips in the new van. Previous van was X50 connected to a Panorama 2x2. Had had a vague feeling the MIMO3 might be slower but no real evidence yet.
I’ve just been out and checked the cables - mine were connected the “wrong but doesn’t matter” way doh!
Switched them around to the “right but doesn’t matter” way and surprising results.
Appreciate this isn’t very scientific, could just be less congestion in the 3 mins it took me to swap the cables and reboot.
Been using the same sim for a very long time and in my previous Huawei mifi with 2 antenna ports and the existing mifi ZTE MU5001 the sim performs very well just not in this RUTX50. It is a voice sim, but i would expect it to perform badly in all the mifi's if this was related to it not being a data sim. I can't 100% rule anything out but i did expect a lot more from this kit especially considering the cost.Are tmyou using a phone sim or a data sim?
I found I was getting appuling speeds with a phone sim in both Huawei 5577 & RUT950
Not sure it’ll make a difference to your issue as that sounds more fundamental, but worth a try.which cables are in which port now? i will replicate it and see if mine shows improvement
I will give that a go and see what happens, worth trying anything at this stage.Not sure it’ll make a difference to your issue as that sounds more fundamental, but worth a try.
Teltonika 1: Cell 1 Main
Teltonika 2: Cell 1 Aux/Div
Teltonika 3: Cell 2 Aux/Div
Teltonika 4: Cell 2 Main
No info on bands on the mifi, its quite basic and the Rutx50 does give you so much information, most i would never probably use but its always nice to have. Not tried it with no antenna's as that surely shouldn't make a difference, i do like the features of this router but if it doesnt increase on the download speed it will not be staying.I don’t suppose your mifi will tell you what band and tower it’s using? Might just give you some more insight e.g. if it’s locking onto a different tower or band.
I can see you tried with the Teltonika rubber ducky antennas - does it get worse if you repeat with no antennas whatsoever plugged into the X50?
Logically you’d expect it to, but who knows with LTE signals. Some might say LTE is even more temperamental than Mrs Brocola, of course I would chastise them for such an inappropriate statement.
It should be significantly worse with no antennas plugged in. If it’s roughly the same, would seem to indicate an antenna (or antenna connection/SMA) problem.Not tried it with no antenna's as that surely shouldn't make a difference
Not that i have seen but this thing is new to me but i have not seen anything in the webui, the RUT955 i suspect is similar but this is their latest 5G supported device so i would really expect this to be flying not crawling.Is there a setting on your Teltonika for external antenna?
I wasnt impressed with my RUT 955 when i had one. Swapped it for a Huawei B535 router which i found much better.
Used a Poynting mimo v 12 antenna with both.
I used to get excellant results with my Huawei 5577 with Poynting MIMO then last year it went to pot was getting 6 - 12 mb/s in the Mifi and 35 - 95mb/s in the phone. That's why I bought the RUT950 I thought the Mifi was faulty but results were the same.Been using the same sim for a very long time and in my previous Huawei mifi with 2 antenna ports and the existing mifi ZTE MU5001 the sim performs very well just not in this RUTX50. It is a voice sim, but i would expect it to perform badly in all the mifi's if this was related to it not being a data sim. I can't 100% rule anything out but i did expect a lot more from this kit especially considering the cost.
There is a good website to show you what mobile service is available in your area - cellmapper.netNo info on bands on the mifi, its quite basic and the Rutx50 does give you so much information, most i would never probably use but its always nice to have. Not tried it with no antenna's as that surely shouldn't make a difference, i do like the features of this router but if it doesnt increase on the download speed it will not be staying.
I will see if i can get another sim just to see if its related to EE where i live but i cant see that to be honest but i am willing to try anything.
i updated it when i installed it as i brought it a few months back but did not get to fit it as needed to swap out the roof antenna's, solwise have come back again today as they are the man in the middle between me and teltonika and they have sent over a beta modem firmware so will flash that and see how it goes. Not happy with the other part of the email though as it says to move the antenna to a better place which is of course not possible when you are using a fixed roof antenna and i dont see how this is relevant when my mifi right next to it seems to work fine.Sounds like antenna ports not working or faulty device to me. Get it swapped. (Given it also doesn't work with the stubby antennas, which should be better than the internal ones in the mifi).
You would be advised to know how to disable band 20 for some areas (North Norfolk) as you will find it so congested to be unusable at many times of year on both EE and Three... but you do need to know how to re-enable it if you visit a rare campsite with zero band 3 signal.
Only other thing that may be an issue I guess is if you've accidentally configured it to ONLY use band 20. This is also possible, on devices I manage, Mikrotik, Teltonica and other brands, I always leave everything eneabled (all bands) when troubleshooting.
Only other thing I can quickly think of is have you upgraded the firmware already? The firmware on many devices includes modem upgrades... some cell towers will refuse to use "newer" communciation protocols unless they see the modem firmware is "relatively up to date".. as bugs in radio stacks sometimes make things worse for other customers if they don't do this in some cases. The X50 is realtively new so I really doubt it's this outlyer.
Indeed if mifi using exact sam sim, it's 100% the router/antenna ports or config.i updated it when i installed it as i brought it a few months back but did not get to fit it as needed to swap out the roof antenna's, solwise have come back again today as they are the man in the middle between me and teltonika and they have sent over a beta modem firmware so will flash that and see how it goes. Not happy with the other part of the email though as it says to move the antenna to a better place which is of course not possible when you are using a fixed roof antenna and i dont see how this is relevant when my mifi right next to it seems to work fine.
I think this may be user error, I can confirm I've had scancom EE sims working fine in both ZTE, Teltonica, many Mikrotiks.zac your EE sim isn't a Scancom sim is it?
Seen some reports in Amazon reviews of Scancom EE sims not working at all in certain models of routers.
Not Scancom no but thanks for checkingzac your EE sim isn't a Scancom sim is it?
The comments don't mention Teltonika, so might not be relevant to you as they seem to indicate a fatal problem, not poor signal.
"We have had many users experience difficulties with 4 different makes of routers:
Huawei
TP Link
ZTE
GL-X3000.
It is something to do with their settings that does not fully allow the EE sims to function".
Check out this Amazon review of EE 5G Unlimited Data Sim Card - Preloaded each month from now until 8th JUNE 2025 - No Contract & One-off payment - Business-Grade Data Perfect for Wifi Routers, Tablets & Phones.
Beware If You Want To Use In A Router !!!!!!!!!!!www.amazon.co.uk
Slightly nerdy, but I'd be interested to know what Firmware version you're currently on and also that of the Beta Firmware...i updated it when i installed it as i brought it a few months back but did not get to fit it as needed to swap out the roof antenna's, solwise have come back again today as they are the man in the middle between me and teltonika and they have sent over a beta modem firmware so will flash that and see how it goes. Not happy with the other part of the email though as it says to move the antenna to a better place which is of course not possible when you are using a fixed roof antenna and i dont see how this is relevant when my mifi right next to it seems to work fine.
Upgraded the modem this evening with no improvement but the info you are after is below, I thinkSlightly nerdy, but I'd be interested to know what Firmware version you're currently on and also that of the Beta Firmware...
I took the plunge and upgraded my firmware over the weekend and I'm now on 07.07.3 and all is good performance wise - all other versions are you have above.Upgraded the modem this evening with no improvement but the info you are after is below, I think
Device: RUTX50
Kernel: 5.10.210
Firmware: RUTX_R_00.07.07.2
Build: ac426cafeed
Build date: 2024-06-10 13:27:01
Firmware version - "RG501QEUAAR12A10M4G_04.200.04.200"
