Our van is perfect…..if only it had a garage!
Our motorhome would be perfect if …..
+1 on the garage, we have a small one ,only wish it was full size to take our bikes.
Loosen all the bolts and spray all the bolds & bushes with PTFE and it will be silent.My moho would be even more perfect if the drop down bed didn't squeak with every movement! It's a Bavaria i600
Thanks, well have a go at that.My moho would be even more perfect if the drop down bed didn't squeak with every movement! It's a Bavaria i600
Surely that's down to Fiat and not Adria. My Campscout needs a bit of tugging after seven days without opening it. Going to try a silicon spray on the rubber seals.I have an Adria as well and have to slam the door to shut it properly. A common issue with Adria.
You know you really want a bigger oneMine would be perfect if the steering wheel was on the proper side, really don't like RHD.
CARAVAN....argh......(makes sign of the cross).....Our van is perfect, it’s a caravan. After having 4 motorhomes where every layout was a compromise our caravan has the best layout and gives us the most comfort. Of course the compromise is Michael having to tow.
Pauline
Did that on our 2011 Pilote following your suggestion about your previous Hymer.Loosen all the bolts and spray all the bolds & bushes with PTFE and it will be silent.
As that doesn't effect the passenger if I was you I wouldn't worry too muchOur van is perfect, it’s a caravan. After having 4 motorhomes where every layout was a compromise our caravan has the best layout and gives us the most comfort. Of course the compromise is Michael having to tow.
Pauline
Our van would have been perfect if it had a roof.
Roof box got caught on a hidden low hanging branch whilst we were going down a narrow lane.
Insurance company didn't want to know, so we had to scrap it .
We now have a trailer and a tent .
Yes, it separated from the body a bit like a sardine tin.What actually happened? Did it rip the roof off? I'm so sorry you couldn't get it repaired x
Trouble is Lois it doesAs that doesn't effect the passenger if I was you I wouldn't worry too much
