Lenny HB
- Oct 18, 2007
- 60,719
- 192,831
- Carthago Compactline
As I said it stays at 14.2v a maintenance charge voltage should be 13.6 to 13.8v.So when it says it 'reduces' after the battery is fully charged, would that be the 'maintenance charge' or a different charge?
Stupid dealer why would anyone fit a battery type not supported by the charger.That's what the dealer put in when we told him we wanted 2 leisure batteries. After all the talk of AGM batteries failing I wasn't that bothered that he hadn't fitted a second AGM and though it might be better to have the ones we have.
With the correct charger and German converters changing to Varta AGM's they seem to be lasting a bit longer but not easy to get a true picture as people who use EHU wouldn't know they are failing, my choice would be Gels.
Tell the dealer he is a pratt to fit batteries not supported by the charger.I can't see the point of throwing out 2 new batteries for the sake of it, if they give me grief then maybe but I suppose only time will tell.
Nope just Gel, Gel' & AGM are both Lead batteries.I've got a Schaudt EBL 119 in the new camper which says it charges as follows, am I right to assume that 'lead-gel' means it is suitable for lead OR gel?:
Me to.Thanks, I really want to understand it all first before I plump for anything, not doubting you at all, I just don't like to put stuff in without knowing how/why it works as it does and that it's definitely the option I want to go for.
On the Gel setting the 16 hour absorption time will possibly cook them. On the AGM setting 14,7v is a bit high 14.6 is normally used for calcium batteries may shorten the life a bit.My Schaudt EBL119 Elektroblok has a setting for lead-gel so it appears won't necessarily 'fry' my Lion Calcium-Calcium batteries as they need a higher charge rate than standard lead acid ones ... have I got that right or wrong?
Eairler reply answers I think. I wouldn't use it with your calcium batteries.It appears that the LR1218 solar controller, whilst not ideal for standard lead batteries, shouldn't cause issues with my Calcium-Calcium batteries (assuming the reduced charge is the maintenance charge as mentioned above) - is that correct?
I would forget about LR1218 passed it's sell by date.
I also notice your batteries have a CCA rating not something you would give a true leisure battery definitely re-labeled starter batteries.
