- Aug 18, 2014
- 25,982
- 155,823
- Transit PVC
- 16 years since restarting
Really ?I can't think of any "normal" car that won't pull top gear at 50mph? Most cars will hold a steady 40mph in top.
The last 3 I have owned here , none would/will
My current transit will just about go along at 50mph (80kmh) but at the slightest hint of a slope it will drop ou the cruise control.Even if you aren't using it it is right on the bottom of the turbo operation.
The previous mpv, which was ato would only lock up at 80kmh & when towing they recommended that you stayed in 3rd gear at 80kmh. I preferred to tow at 100km/h which not only allowed top gear but lock up as well.
The previous Transit torneo connect would not travel at 80km/h in top it would start to hunt & shake the vehicle to pieces.
The current van when I am travelling in France in the 80 limits I use cruise in 4th , 70 limits cruise in 3rd & 2nd in villages.
Even when I returned from Poitiers in a hire car last year it didn't like 80km/h in top
But only if you do not have to change down the gears . which for me is not possible & nor is it in any vehicle I have owned or even the ones my mate owns & that I use.You get more MPG at 50 than at 60mph... Using less fuel = less emissions. That is the logic.
Mine drops out at 50mph in top at the slightest hint of a slope & the design is such so as to prevent damage & also , as you well know, if you are in too high a gear going to slowly you do not have proper control of the vehicle.I wonder how many people with a manual car and cruise control will just leave in a higher gear and not change down for an incline etc. Leaving the car not in it’s optimum engine speed.
Many exhausts emit cleaner air than what enters the intake?Whats pleasurable about being poisoned by exhaust fumes?
As above even on a flat road at 80km/h (50mph) as far as I am concerned with no turbo available due to being barely in the working range, I do not consider I have complete control of the vehicle & cetainly wouldn't have any engine performance to get out of trouble. It has to be within the turbo range so needs a lower gear..
