skylinersi
I daren't! swmbo would kill me if I spend any more !!!!
just kidding, its nice to get the heads up on some useful gearBe nice if we were! Can't even benefit from Funster discount on Clutch Claw as we already have two - both bought years ago & transferred as we changed vehicles - that was a good investment though
Hope you have liked the things that you bought? Some, like the Colapz (Flopro) watering can are a bit Marmite - have met Funsters on rallies who went on to buy more as they carry two & others who sold them on.
Hi - all 4 came with the fan some years ago. We did try to find spares rather than remove them (leaving small screw holes to fill with white silicone) from our previous motorhome but didn't find any online at the time. Perhaps a Fiamma agent like Johns Cross www.johnscross.co.uk can help? They do give Funsters discount too Link RemovedHi Wombles Where did you find the 2 'spare' brackets - having 4 will be much more practical than the 2 we got with the fan.
Hi Karen and Alan, hope you are both well hope to catch up will you somewhere soon. We are following your posts as we are changing to a pvc due to Michael unable to renew his C1 licence due to health reasons.
We are collecting a Malibu 640 on 9th September, it has been on order since February sadly delayed due to Covid. We were ordering a rear door lock from Womo-tuning and found your posts looking for a discount code and are now going to order a sliding door lock too.
Best wishes Sue and Michael.
Hi - great to hear from you both & look forward to seeing you in your lovely new pvc sometime!Hi Karen and Alan, hope you are both well hope to catch up will you somewhere soon. We are following your posts as we are changing to a pvc due to Michael unable to renew his C1 licence due to health reasons.
UPDATE: Womo-tuning have now changed name to Camper Protect https://www.womo-tuning.de/ but our 5% Fun discount code MOTORHOMEFUN-UK is still workingExciting post arrived today & the best solutions to securing the sliding door & rear barn doors from inside for us that we have found from https://www.womo-tuning.de/ in Germany. If anyone does want to order any of their well made products then they have kindly agreed a 5% discount code MOTORHOMEFUN-UK for Funsters
See post 186 above for tips for buying from overseas.
This lock €34.90 (minus discount plus €9.90 shipping per order) is for the sliding door:
For anyone who needs a longer version (for the Malibu van for example) it may be available so worth emailing but the website listing does mention that this will not fit Hymercar as their interior trim is different.
Always found a normal small door bolt fitted to rear of sliding door does the trick,,BUSBY.Are these for use whilst you’re sleeping in the van? I am always cautious about delaying an exit in case of fire. Smoke and panic induced adrenalin can cause disorientation .... My parents always locked both outer and inner front doors with keys and Chubb locks and kept the keys in another room. Luckily, they never had a house fire; the worst was they couldn’t open the door quickly enough to get parcels before a card was pushed through the door.![]()
Hi Karen, does that OBD lock fit the ducato x250 do you know?We are also thinking about an OBD Lock with added Extension <Broken link removed> from the same company when we get the van out of hibernation! Even with the two parts (so two locking parts) plus shipping work out much cheaper than the other locks we have found so far for this.
Hi - it's listed for it on their websiteHi Karen, does that OBD lock fit the ducato x250 do you know?
Have a look at this excellent review by TheBig1 https://www.motorhomefun.co.uk/foru...but-fits-from-06-onwards.227627/#post-4107011 . We have only just ordered ours today!How does this fix to the OBD?
We didn't spot it at first - UK is Vereinigtes Königreich on the drop down at checkout - so should be €11.90 p&p on top of listing cost.Just ordered one but cannot find U.K. in the country lists so hope they use my PayPal address.
It helped me that Brenda is fluent in GermanWe didn't spot it at first - UK is Vereinigtes Königreich on the drop down at checkout - so should be €11.90 p&p on top of listing cost.
That's handy! The website translates into English (using right click) but not the drop down & most useIt helped me that Brenda is fluent in German
Had quite a bit of rain since fitted & can confirm it works wellMod. for today was fitting a rain gutter strip over the sliding door to reduce the build up of water on top of the door that then pours in on opening. After much searching bought 1.5m Reimo rain gutter from Kiravan https://www.kiravans.co.uk/prod.../plastic-rain-gutter-150cm for £20.25 delivered. Some discussion about this & other options here https://www.motorhomefun.co.uk/foru...-over-sliding-door-on-van-conversions.202952/ . Pleased with how easy it was to fit & hopefully it should work well & be durable enoughas designed for exterior use over cab doors.
Fitted our OBD Lock today - went on well & pleased with itWe are also thinking about an OBD Lock with added Extension <Broken link removed> from the same company when we get the van out of hibernation! Even with the two parts (so two locking parts) plus shipping work out much cheaper than the other locks we have found so far for this.
UPDATE: Cobadot vinyl flooring still good after 2 years use, doesn't move, wipes clean easily & has just a few superficial marks. Available by the metre here https://www.cromwell.co.uk/shop/cromwell/prod/1-2m-x-1m-x-2-5mm-blue-cobadot-vinyl/p/CBA9465061B & easily cut with scissors. Don't forget to contact them if you want 2 continuous metres as otherwise it is likely to come as 2 x 1m sections! Photo taken today:Our motorhome has a tough flooring surface bonded to the floor board but still want to protect the garage floor from scuffs & scrapes so after trying lots of samples chose this Cobadot vinyl flooring to loose lay cut to size - it’s available in blue or black at 1.2M wide & can be bought in 1m sections from but if ordering 2m it is likely to be two sections not a continuous sheet unless you request that. If going via Quidco to Zoro then 3% cashback possible & £17.99 per metre plus £4.99 delivery but if order over £20 then free delivery. Also 5% discount code “ ZTOCT18 “ for next 17 days
Haven't fitted it yet as so many little jobs to do but it cuts easily & doesn't smell of rubber like many other dot floorings.
How did you fix it. Sorry if that’s a dumb question !A suggestion from a helpful member (thank you Philipp) of a Facebook Group that we run was to fit a tow loop strap to the door bumper on the sliding door :
This is our version fitted today:
Bought this TRS tow loop strap in black (other colours are available) from here http://rover.ebay.com/rover/1/710-5...0001&campid=5338547443&icep_item=182883649204 £10.99 delivered but did unpick & remove the label:
It's a well made heavy duty loop & so far it does seem helpful for controlling the sliding door but doesn't flop down out of the way like the OMP version. Cheaper versions are available from £4 on eBay.
