More Fiat starting woes
Lizbiebrowne
Teesside
Hymer B654
Since 2019.
Not content with thwarting my engine starting attempts by intermittently showing me the yellow key/padlock warning light on the dash (https://www.motorhomefun.co.uk/forum/threads/fiat-😡.311253/), my Fiat 2.8JTD engine has now developed another strategy by occasionally refusing to even turn the engine over when I turn the key to start it.
Any thoughts? I’m think perhaps there’s a relay involved somewhere, some poor connections or the solenoid. Not happening often (yet) but worrying nevertheless.
L
Lizbiebrowne
Teesside
Hymer B654
Since 2019.
Have you checked all the earth points and starter cable?
I know something about engines but not good on details so I was looking for some pointers. I’ll take a look at those items (if I can find them!) tomorrow. Thanks.
East sussex
2002 Eura mobile
Since 2014
Having had similar problems in the past on my last 2.8jtd I suggest it may be the ignition barrel itself. I bought a new barrel with keys easy to change once you remove the headless bolts. I then taped the original key to the security sensor ring & tucked it under the dash. No more problems after that.
There is a small contact at the bottom of the ignition barrel which can wer or corrode resulting in no contact when the key is turned, ignition comes on but the next bit fails hence the starter doesn’t turn. Check if you have a row of fuses itthe nearside top dash pocket on some models there is a 5 amp or 2 amp that works theimmobiliser take it out and clean the fuse twisting the blades a little may help. It’s model specific ours was a 1999 2.8 JTSD
L
Lizbiebrowne
Teesside
Hymer B654
Since 2019.
That might solve my other problem too - what year was your 2.8jtd?
Mine’s a 2003 model.
L
Lizbiebrowne
Teesside
Hymer B654
Since 2019.
If you go for a replacement coastal Motorhomes is where I got mine. I tried just replacing the switch part from eBay but it didn’t work.
Thanks Baggy. I’ve also have the additional problem with the immobiliser chip not recognising the key on occasions so although replacing the barrel might cure this starting problem I may still be left with the immobiliser problem even if I take your approach and tape the key to the sensor.
West Sussex
Malibu Van 640 LE K
Since 2003
That might work but presumably it removes the immobiliser protection. My NFU insurance specifically states a minimum requirement of a Cat 2 immobiliser for theft cover and I suspect most insurance companies would consider it to be an unauthorised modification.
Rochester
Auto-Trail Mohawk
17 fun filled years
I had similar problems with starting and replaced just the ignition switch that I bought off fleabay, not had a problem since.
Plenty of guides on YouTube on how to do it.
