And he’ll take Mobi in px for a fair priceSo just been speaking to Gareth.
Everything sorted with the Flair then?So just been speaking to Gareth.
I wish lol
Well sort ofEverything sorted with the Flair then?
I would go Exide Gel unless you are going to go Lithium in a year or two, the G80 ES900 should fit in the under the boot floor position as they are not too tall.Well sort of
So when he went to collect the van from the garage they told him that the belt they took off looked like new ...so not sure if it had been done at something while it was parked up or if it had been changed before that ... but anyway they fitted a new dayco belt.
But they didn't get the other belts but the mechanic told him they also looked like new or they wouldn't have put them back on . They're now on holiday so I'd have to wait a couple of weeks to have them replaced so I'll just check those out when I get it back here. At least the main Campbelt has been replaced.
He said it was just over £500
Then he checked about batteries for me .
For 2 lead acids banners it would be £215
for 2 exide gels £396 ...Still waiting for him to tell me what size those are as he's a bit clueless with stuff so he's got to check with the supplier.
I'm unsure what ones to fit .
Just smiffy checked tayna batteries and they have exide es900 g80 gel batteries for £296 for 2 .
So for the electric guru's what's your thoughts
I think I'm gonna remove the satellite dish and fit a 400w solar panel above the rear bed and garage and a victron controller. If the generator works I probably won't fit lithium later , if it doesn't work I probably will .
So for now am I better buying the cheap banner batteries or am I better buying the 2 gels from tayna the same as Just smiffy has in his van.
I wouldn't touch Banners with a barge pole as they say.For 2 lead acids banners it would be £215
Listen to uncle Lenny and get it done, just drop in with a few bottles of good wine and gin and he will sort itI wouldn't touch Banners with a barge pole as they say.
Exide gels are great batteries normal one fitted is 80ah but you can discharge them down to 20% but they take longer to recharge & not to keen on high current loads. They charge up to 80% quickly but then need 4 to 8 hours of absorption charge to get to 100%.
Until the new van I've only ever had Gels life span of 6 to 10 years more is not uncommon.
The Fogstar Drift Eco 100 ah is £220 (£198) or 305ah £500 (£450). No Bluetooth so you would need a shunt to see state of charge. Two of the 105ah same price he is quoting you for Gels.
And if you can’t get there without the new batteries he could just give you a shopping list and then have him on a days WhatsApp video call so he can guide you along lol, or pay for his fuel, he might fancy a few days in beautiful WalesListen to uncle Lenny and get it done, just drop in with a few bottles of good wine and gin and he will sort it
That's one of my concerns as I didn't measure the battery box in the garage but I want 2 batteries to fit in there and have the cover over them . At the minute I'm not sure if I'll need lithium it depends on the generatorI would go Exide Gel unless you are going to go Lithium in a year or two, the G80 ES900 should fit in the under the boot floor position as they are not too tall.
I know he don't like bannersUncle Lenny will tell you Gels!
Or AGMI know he don't like banners
The battery box will pobably be sized for 2 x Exide ES900 gelsThat's one of my concerns as I didn't measure the battery box in the garage but I want 2 batteries to fit in there and have the cover over them . At the minute I'm not sure if I'll need lithium it depends on the generator
Is the “box” two length ways or side by side?
The battery supplier that guy uses told him that he knew the standard fitted batteries to that van and that was the 2 choices he gave ..so it probably is those. But if it is he's charging 100 quid more for them than tayna
It's side by side . I have a photo but it's on my other phone .Is the “box” two length ways or side by side?
Don’t think there was a pic of it
So the box will be around 350mm ish square by 190mm ish high, any standard size battery should work if you staying lead for now until you can test the genny and see what your use is likeIt's side by side . I have a photo but it's on my other phone .
Certainly on our Flair Exide G80 were the factory fit.
Here it isSo the box will be around 350mm ish square by 190mm ish high, any standard size battery should work if you staying lead for now until you can test the genny and see what your use is like
But could I fit lithium without having to change the chargers and all the cables etc just now?I wouldn't touch Banners with a barge pole as they say.
But could I fit lithium without Uncle Lenny having to change the chargers and all the cables etc just now?
I have the same generator as you will have TEC29 but have 960ah lithium too, the generator is only used in emergency and also when driving I run it along with the B2B to charge the smart car and also run the habitation air-con when driving to make sure when I arrive where I’m going the inside of the van is coolerThat's one of my concerns as I didn't measure the battery box in the garage but I want 2 batteries to fit in there and have the cover over them . At the minute I'm not sure if I'll need lithium it depends on the generator
Yes I don't want to rely solely on the generator ,its mainly to run the 240v appliances , Aircon, microwave etc but as I'm not a heavy power user and I plan to fit 400 watt solar to it and eventually a b2b I'm not sure if I will need lithium. But don't plan to fit it this year either way . I will be fitting solar and a controller though before I head off this winter.I have the same generator as you will have TEC29 but have 960ah lithium too, the generator is only used in emergency and also when driving I run it along with the B2B to charge the smart car and also run the habitation air-con when driving to make sure when I arrive where I’m going the inside of the van is cooler
Yeah I'll get the details of the charger etc when I pick it up.If you fit Lithium, & you are fitting a Solar regulator you would really only need to fit a B2B the existing mains charger set to Gel will be OK for occasional use.
Chan you get the model number off the charger? So I can check.
