Minxy
- Aug 22, 2007
- 35,141
- 76,673
- Carthago Compactline
- Since 1996, had Elddis/Swift/Rapido/Rimor/Chausson MHs. Autocruise/Globecar PVCs/Compactline i-138
Just watched the video and a couple more observations:
Work surface extensions: for the one near the driver's seat I was thinking of it pulling towards the front of the van (ie side of the unit), so closer to the swivelled drivers seat making it easier to eat/work off, rather than out to the side which may make it a bit of a stretch in reality. As for the kitchen flap near the sliding door, I wonder if you can use a similar pull out worktop for this rather than a lift up flap, the benefit would be you could pull it out as much/little as you needed, obviously it would depend on what equipment you have in the kitchen unit itself and whether there would be sufficient space for this.
Lockers over the rear bed: I think you'll miss the storage and if you plan them right you will still have more than enough room to sit up, eg the mattress top in our camper is at the same height as the kitchen unit and we can sit up under one side which has shorter lockers, there's no reason why they can't be short in height but have a good depth to maximise the storage space.
