Might Re-Selfbuild our van. Thoughts on this design?
Wissel
Horncastle, UK
Van Conversion
Since 2006
We are planning on going full-time next year and the plan was to buy a 7.5m coachbuilt for this.
After planning this for months, we've had a re-think and are now thinking about re-building our selfbuild to suit full-time living.
The downside (as I see it) is losing the extra space of a bigger van. But the upsides are we can park our 6m van in most towns with ease (it's been our everyday vehicle for 5 years), it can get places bigger vans can't (width), security is probably better, oh and it would save about £60k :)
So I started on a re-design a few days ago and would love opinions on it.
This is our van now:
It has a nice big u-shaped lounge that makes into a huge bed. It has a bulkhead with a sliding door, great bathroom, underslung gas with crash sensor, underslung water tanks, Triflo cooker and a great electrical system (4 x LB, solar and great chargers).
Thing is, we are lazy so leave the bed out all the time. With the bulkhead, the cab seats are segregated from the living part, so there's nowhere really to sit. This is fine for a weekend away - but no good to full-time.
So this is what I'm thinking of building:
The bulkhead would be gone to include the cab area into the living area, the u-shaped lounge would instead be a permanent 3 single/double bed - higher up to give a bigger boot and lay flat wardrobes under each bed (40cm deep) and the area under the right bed would have a hatch from the steps into a space for the dogs bed.
As well as a table that can be erected between the front seats, there is worksurface befind the drivers seat and a flip-up table in the kitchen, these give surface area to each front seat for lounging with a coffee and a laptop.
Gas and water would stay the same, so would the bathroom (but re-built). The electrics with change to 300Ah of lithium and more solar. The lithium batteries will be connected to a wired in inverter, so we will have 240v all the time.
Would appreciate any thoughts on this design?
Cheers, David
My initial thoughts are that it's the wrong layout mainly because of your daytime seating area. Our front seats turn all the way so we are facing the middle section of the van which includes the kitchen area ad well as a double seat where we can stick our feet on. Also our fixed bed is transverse which gives more room in the van. We use the van in Winter for 6 months so a comfortable seating area is important but so is a fixed bed.
If your seats only turn and face each other as they appear to do then I believe that you will struggle
Hello Wissel, I finished my self build earlier this year and have completed a 2000 mile tour of Spain. This sounds a bit conceited but I can honestly say that I wouldn't do anything differently. I have put another locker over the microwave though.
Anyway if you would like to see it, put "Calida 6000" into utube.
Hope this helps.
Sorry Mikeco - this is just me not making things clear :)
The seats will rotate all the way around. We will have the choice of rotating them 90 degrees and using a table in the middle - so a diner type layout, or rotating them 180 degrees and having a surface in front of each table. Surfaces are important to us as we both work online.
I downloaded Sketchup this morning and watched a quick guide on how to get to grips with it's basics. These drawings are simplified, but hopefully give a better idea than my terrible flat plan in original post :)
Hope this helps.
Thanks - I'll take a look (you can see my original van from my signature if interested) :)
As you'll be in it all the time make sure that you can comfortably sit up in bed as the chances are you'll spend a lot of time slobbing out on it.
These are some photos I took of converters' vans when I was thinking of doing my own conversion which may be useful/give you more ideas:
ours was very similar to what you plan we originally use a table on a tripod to fit diagonally between us but then went to a boom table for passenger and driver could eat of the end of the kitchen
one of the reasons we upgraded to a coach built was no lounging space ,seats are comfy enough to sit on but you cant loungei dont think in a 6m pvc with a fixed bed you can get a proper lounge
remember when you remove the bulkhead your left with a 4 inch step between can and rear wildax fit fooot rests to the rea of the seat box otherwise you will suffer from dangly legs we just used two caravan step that stacked
there isnt room to sit facing each other with the seats turned 90 degrees this may have been due to the seats we had
The layout looks liveable. As you are going to be using it all year if your external tanks aren't already winterised I'd be looking at enclosing them in insulated enclousers and having a heating feed from the blow air system, also worth putting a blow air feed into the loo cassette area.
Thanks for that - I wasn't sure if a table would fit with the seats facing in other. In that case a little adjusting and this layout (for table should work:
Our's would differ in that above the fridge would be a surface instead of a wardrobe - giving a permanent table of sorts (well - somewhere for me to have my laptop if Missus is still in bed lol). Maybe a similarly placed table to the above pic, but elongated to eat from might be the answer.
Lounging wise - I think we are sorted. At home we never "sit" on a sofa, both of us always have our feet up. It's the same in our currently laid out van with u-shape lounge. So what I thought I'd do is build both sides of the new bed design so they can incline.
Even working from home I work crashed out on the sofa far more than from my office. I have a cracking little laptop table that adjusts all over the place - I use this in the van as well.
Like this for anyone interested:
Amazon product ASIN B01HZ51K0Q
I like the idea of encasing our tanks and feeding hot-air into them. They are next to each other under the van, so it would be an easy job to box them in insulated aluminium or something and feed a vent into the box.
Our existing air-vents already feed into the front, rear, cab and bathroom. I'd probably do pretty much the same this time around. Last time I also fed the ducting through the boot as I figured it would give a little background heating.
ours was much like that but our kitchen worktop was behind the driver so like you say you can use that, for the other seat we wound up with a boom table that folded flat against the back of the passenger seat when not in use its realy difficult to get a table big enough for you to both eat off comfit ably
the other problem was with the step standard pole mounts are not high enough which was why we had the fiamma tripod as it raised it a bit
Older Hymers had a ply box lined with PU foam and lastest ones it's a GRP enclousure lined with PU foam.
If your system is Truma they do branch connectors that take 22mm ducting that is what is normally used to feed the hot air to the tank enclosures, obviously the enclosures need an air gap around the tank.
Great thread Wissell
As you know I have been designing our PVC on a 6.36m van but have kept changing the layout.
The best layout is the rear u shaped lounge that is great for lounging during the day and makes either 2 singles or a big double. The problem with this layout is storage space, there is not much at all, you get good storage with your idea but you can never have a double and the wife says we sleep together at home so why not in the van.
I cannot think of a solution at the minute, was thinking of getting the H3 van and raising the rear lounge and consequently the rear windows in the lounge so you have more storage, but then you have a higher van.
Will it take a lot of afterthought to get the outer double skin around without taking the tanks off etc.
You can buy double skinned water tanks as well.
I'm fairly sure my tanks are double skinned anyway - at the time (5 years ago) I spared no expense on the build and put the best bits I could find in it (for me). My tanks are Barrett Tanks.
Because of the way they fit, adding an outer casing should be fairly easy:
I can make something that attaches to the existing bolts and the holding bars will give a nice gap for air to circulate. Then just a case of plumbing a vent into the area, and an air escape vent into the boot area.
At the moment I'm giving it a really thorough clean as before I decide for sure to re-convert it I want to make sure everything that can be is as close to perfect as possible. This will include sealing the underside.
Think once it's clean I'll get it up on ramps at my local garage (they are so obliging :) ) and get some images and measurements for a casing. Looks a fun job anyway :)
Barrett tanks do the skinned but you have to specially order them. It looks a nice job for you to do, don't know why they all don't build them like that, it wouldn't take much more to do as its being built. That's the problem with manufacturers of PVCs, they don't pay enough attention to insulation and winterisation.
Its not just the tanks though its any exposed water pipes underneath too, even short runs will freeze.
We have a 6.3 m IH rear lounge conversion. Your solution of raising the rear seats to make a garage space is a bit "robbing Peter to pay Paul" as the saying goes, we have upper lockers that wrap all around the rear half of the van and they give a lot of storage, you would not be able to have these and sit up in bed. We are currently in France and it's quite warm!!. Do think about how you would be able to get a good airflow with the restricted headroom in the rear. We have side, back and roof windows but still hot in bed.
Yes but he has a white van and quality insulation, cooler in summer and warmer in winter.
I'd drop the idea of a central table for you both to use as you'd probably find you end up getting fed up of moving it out of the way all the time, or 'tap' it and knock your drinks etc over! Instead I'd put a boom arm one next to the passenger seat which can be folded out of the way and/or have a removable top for when you don't need it, then behind the driver's seat have an extension flap to lift up/drop down. My personal preference though if I was building it would be for one that slides out from between the fridge and work surface, a bit like the below - this would mean you could still have a shallow cupboard* at the back of the work surface, leaving some in front for your cuppa etc when you don't need anything else, it would also mean that you didn't have to clear everything off the surface to be able to use it for your laptop (which would be a bit of a stretch to use comfortably anyway with no-where to put your legs) and the pull-out extension could be slid in/out much or as little as required (just make some stops for it so it doesn't move when you use it) and would store completely out of the way when not needed.
* If you did as I've suggested and put a shallow cupboard at the back of the worktop, don't have the door opening the full height and instead make it at least 6 inches shorter and block off the front at the bottom of the cupboard, that way if you need to get in it with stuff on the work surface you won't have to move the items to get at the contents of the cupboard.
... remember when you remove the bulkhead your left with a 4 inch step between can and rear wildax fit fooot rests to the rea of the seat box otherwise you will suffer from dangly legs we just used two caravan step that stacked
Doing something like the below would get over the problem of the 'gap and dangling legs as well as create a bit of extra storage:
you will be suprised how you can have a raised bed and lockers our lockers in our old self build were huge compared to most and as you can see in the picture quite close to the bed but they were never a problem we could still sit up
@Minxy Girl - You're a genius :)
A slide out table above the fridge would work perfectly for what I need it for (bit of desk area to work from) and as it stands, the surface above the fridge is 6cm lower than the kitchen surface.
Adding this table brings it nicely to the same height without wasting any space. Thanks :)
Just one other thing to think about, if you have the bed so that you lay with your feet at the rear door you will be able to put bigger lockers transversely and down the sides, with shallower/shorter ones above where you will sit up in bed (ie with your backs to the washroom and kitchen area), this means that if you have the rear doors open in nice weather you can still lounge on the bed and read etc and it will also be easier to get in/out of the bed as you just need to swing your legs over to the steps rather than try to 'riddle' down to them.
I believe that if you're going full timing, you will need a bigger van. Even if you do redesign your van it still won't give you the storage you'll need.
Have you checked out motorhomefuns sister fourm, it's called diymotorhome.co.uk very good site for self build vans.
Darcar.
Darcar.
Funnily enough I just replied in another thread to you on diymotorhomes :)
TBH, the storage isn't a problem. But thanks anyway :)
Darcar.
Ah but he can always add a roof box and/or a trailer if necessary.
I think I'm starting to get somewhere close to a final layout for my re-build :)
This is the bed design:
The right hand side is 2m long (I'm 6ft), but the left is just 1.8m (missus isn't 6ft lol). The beds will be somewhere around 1m high, leaving about 85cm in headroom.
The mattress's on each side will lift on gas struts to reveal our wardrobes. These will be around 30cm deep and cover the whole mattress area on the left (so a robe 1.8m x 75cm x 30cm) and the first 1m on the right side. That's a lot of robe space for a PVC I think.
Underneath the robe on the left will be the boiler, water pump and a few other bits. Under the right side will be an open area roughly 1m x 70cm x 60cm high, which will house the dogs bed. His bed has been a major pain in our van, as it takes up a lot of floor space. This way it won't, plus will serve as a crate for travelling.
From the rear doors, this will be the storage:
At the bottom is the boot. This is the full width of the van, 50cm high and almost 1m deep. The space above on the left will house the vans electrics. These will be 300Ah of LifePo4, a good inverter wired to all 240v sockets in van, the solar etc.
I'd have preferred the LB's nearer the front of the van, but just not possible in this design. Means I'll need a very heavy duty cable front to back (I'd guess 70mm without working it out), but on the plus side the batteries are quite light for 300Ah (40kg total and 360mm x 220mm x 350mm high).
You might be able to see from the drawing above that the left bed is deeper than the right. This is to maximise access around the area as the bed will finish inline with the bathroom and kitchen:
This gives us a bathroom 1m x 70cm, which is what we have now. This will have a tambour door, making access a little easier than our current door that swings across the walkway.
The kitchen area opposite is 1m x 55cm. Most of this area is taken up by a Thetford Triplex oven and the sink, so there will be a "flip-up" surface at the end of the kitchen that will fill the sliding door area when deployed.
To the left of the bathroom is a fridge. This has a worksurface above that means with the swivel of the driving seat I have a desk area to work from. This desk area will have a slide out extension for when needed, and also serve as a dinner table from the drivers seat.
A dinner table from the passenger seat will be served by the kitchens flip-up surface.
I haven't bothered drawing the wall units in, as fairly obvious where they will go. Although, above the bed there won't be units all the way around, as I think they would kill headroom.
Think that will do for now. What do you think?
Nice, just some observations:
Bed size: I understand you wanting to have the two different lengths but I'd stick to the same width (depth) at the widest point near the rear doors as the taper to the kitchen area can be made to any angle. It might be an idea to see what size 'off the shelf' bed frames you can get as this may influence the exact size of the beds themselves. thinking about it you may not have to put such a large tape on the bed bases as the bed frames can overlap the edges of them anyway.
Bed storage: I'd cut the left bed storage area in half across it's length so it's similar to the one on the right and instead have access via the rear doors as for the other bed, either with a drawer or flap otherwise getting stuff out, even with struts to hold the base up, will be difficult (similar arrangement on a previous MH bed and it was a pain!). Also make sure you put an access hatch in the area below the dog bed bit so you have some 'hidden' storage for stuff, and also lift up flaps on the steps to access those areas too.
Batteries: I'd be a bit wary of putting the batteries on a 'shelf' instead of directly onto the floor - would you be able to incorporate them into the enclosed area near the boiler with an access hatch from either the bed base or the rear 'boot'? This would also allow you to put them a bit closer to the front of the camper thus reducing the cable length.
Kitchen: Be careful about putting a very large lift up flap there as it can be an absolute pain if you have stuff on it and want to get in/out via the side door! Instead I'd be tempted to put on a smaller on and then a larger one on the other side so it goes over the end of the bed, similar idea to the below where the worktop bit drops down leaving a bit of framework (obviously smaller one needed for your PVC) which also gives some 'privacy' to the bed area, then use a swing/boom arm table for the passenger side.
Was thinking of you last night when I went to bed. The shelf above the back cushions around our rear lounge is a godsend. It is just wide enough to take a mug or a glass and you can put essentials to hand at night, I always have alarm fob, keys, spectacles and phone to hand at night. The little corner shelf is hand too when we don't want to put the table up.
Our Regal made, a IH cushions are nice and thick so the shelf not in the way,
Totally agree @Riverbankannie - we have the same shelf in our van now and wouldn't be without it :)
I't's going into the new build, but will be level with the bed no probably not quite as useful.
