Microwave screw holes
Bristol, UK
Bailey Advance 66-2
Since Sept ‘21.
We need a new microwave for our van. Do you know whether the screw holes, used for anchoring the microwave on its shelf, are to some sort of standard? Ie can I be confident that any m/w that I get will have the holes in the correct position? None of the tech specs specify this detail.
MisterB
Adria 670 SLT
We installed aluminium angle on two sides and the rear, and utilised a strip of wood along the front to keep it in. Works perfectly for us
DaveHobson
Bristol, UK
Bailey Advance 66-2
Since Sept ‘21.
Sounds like a good plan. Not sure what you mean by ‘aluminium angle’ though? Would it be easy to provide a picture?
MisterB
Adria 670 SLT
B&Q ... Just standard aluminium angle in 1m lengths
PP Bear
Kent, UK
Auto Trail Dakota SE
Mine sits in the cupboard on a sheet of underlay and has been that way for 18 years now, without any issues, I’ve never thought or needed to anchor it 🤷🏼‍♂️
MisterB
Adria 670 SLT
I see, thanks - so that stops it moving, and the wood along the front stops it falling forward?
needs to be thin piece of wood to ensure the door can open though, again b&q will sell thin beading that will work. the beading needs to be no thicker than the feet on the microwave as in effect its only the feet your looking to stop sliding forward, not the microwave as such, stopping the feet sliding will stop the microwave sliding.
we bought a standard microwave and had it downrated by a company in kent, on the way to the channel tunnel, took him less than an hour to reduce the power consumption, yes it takes a bit longer to cook things but doesnt trip the site electrics on ehu, but for us it allows us to use it when not on ehu as the draw is less than the lithium battery is rated for AND we can use the kettle at the same time as the microwave (again when ot on ehu!)
If a standard microwave, pop the cover off and check clearance where you need to drill holes. Then bolt on some ali angle but use nylon nuts.
My only concern with it not being pegged down is this.
In an accident it would fly around and the transformer in it weighs quite a lot. Having that hit you in the back of the head is not likely to be conducive to good health?
Manchester
A class Hymer
Since the 80s
That's similar to what I did. Then when I went over a speed bump too fast the microwave bounced up and ended up on the floor. What I do now is use a rectangle of plywood. The feet are probably held on by a screw into the metal case. So get some longer screws that go through the plywood and just reach the metal case like before. Make sure they are not too long of course. Then hold the plywood down onto the shelf with a couple more screws. You can get nice veneered plywood and varnish it with polyurethane varnish.
MisterB
Adria 670 SLT
just to confirm, our microwave CANNOT just jump out, though the comments some have made to ensure that doesnt happen are very good advice. to remove our microwave, you have to remove wood trims that stop it from either jumping out or being removed, sorry for not making that clear earlier.
Pilote P732 2011
3rd Time around, since 2000
Here,, something like this might help you in your quest to fit a replacement.
What motorhome are you replacing microwave in?
DaveHobson
Bristol, UK
Bailey Advance 66-2
Since Sept ‘21.
Thanks, that’s useful. Not sure about drilling holes in the microwave, but he seems to have got away with it! We have a Bailey Advance m/h. In this Bailey caravan, the m/w is mounted on a separate plywood plinth - ours isn’t, but, as suggested by others above, I could do that with the new one.
Pilote P732 2011
You could as it will be easier to get it right out of the cupboard first then mount it in cupboard.
The feet are a good way from anything else in the microwave so should be do able.
Just mark the bottom of the feet with oil or margarine and get other half to assist in dabbing it on to the wood then you should have the position of the feet. Small drill bit next to open a hole that a screw will expand out to a tight fit
Hymer B578
Just starting out
Socks and sandals, Keith? tut tut...
Tombola
Merseyside
Rapido 8094DF
I screwed down with something like these, making sure the innards of the micro was clear.
Congleton
Bessacarr 494 lounge
I had the same dilemma,so had the original one repaired
