We are currently in France and the temperature is extremely high. We have been running the Maxxfan for long periods and after a while it stops responding and cuts out. Anybody got any suggestions? Many thanks.
Simpler suggestion:We are currently in France and the temperature is extremely high. We have been running the Maxxfan for long periods and after a while it stops responding and cuts out. Anybody got any suggestions? Many thanks.
Yup! Ours is close enough to the hob to work as an extractor fan. Gets very gungy!Not related to the problem but has anyone ever noticed the gunge that builds up on it. While cleaning the van I've always overlooked it till the other week when it caught my eye. I was shocked to see it
Details from the stabilizer:Could one of you clever clogs post more info on stabilising the voltage please?
Weāre suffering the cut-out problem too. I fitted the fan myself, tapped off the lighting circuit. Had no problems with it until this summer - after Iād upgraded the solar and B2B charging (Lithium LB).
I REALLY do not want to have to remove the fan from the roof to do this, but can access the wiring where I tapped into the lighting circuit easily enough.
Thnx,
Heeb
Thanks Peavy - donāt think Iāve the space for that setup without some serious rewiring!Details from the stabilizer:
INPUT side:
OUTPUT side:
- Nominal voltage: 12/24
- voltage range: 8-40
- efficiency: 90,8% (12V input)
- voltage: 12 (I read constant 12,2V with my multimeter being 14V in the input)
- maximum rated current: 10A (Maxxfan uses 3A at 100% speed).
- voltage and load regulation: +-1%
- standby current: 54mA (at 12V input)
The stabilizer is not that big, as you can see in the picture, you can fit it anywhere and the wiring is quite simple.donāt think Iāve the space for that setup without some serious rewiring!
Not installed it hoping to do it on Wednesday weather permitting.@Lenny HB - how did your experiments with an in-line diode work? And did you knock up a board to hold it, or are there automotive plugānāplay versions?
