hi ,,having a big garage is great, first time away with it, i found myself just throwing everything in ,,but has anyone got ideas about good loading methods how to use the space better ,,thanks
Are you opening a mobile kitchen?
Edited for you free of charge to ensure accuracy.Reading this it's obvious that just because you have some spacemanymost feel the need to fill it.
OftenwWith a load of crap![]()
It seems you if you buy a big van with lots of storage you need to fill the storage with lots of items to use the vanEdited for you free of charge to ensure accuracy.![]()
I noticed you convinenantly didn't mention your garage is almost big enough to get a small car in.I have places for things,
the ladder get tied up near the door,
the windbreaks have a proper [lace on the back wall,
the toolbox and hook up cables etc have a space in the alcove bits at the front,
the table fastens against the back wall and the outside matt stands in a bucket for when it goes back in wet,
the bike panniers hang on the back wall,
that then leaves the floor space clear for bikes and a few boxes/bottles of winegot the priorities right
4 chairs, folding step ladders and a few other things go in a locker at the front.
Really it all depends what you are trying to fit it.
And why not.Reading this it's obvious that just because you have some space many feel the need to fill it.
Often with a load of crap![]()
And why not.![]()
I liked that with the frankia and the euramobil...it had huge lockers under the front lounge that went across the whole van , a proper double floored set up . Was amazing what you could fit in there.Nah it's not that bigI like the fact that we have other outside storage options though so keeping the garage floor area clear of rubbish.
Very organised.
A very neat garage. Have a BBQ like that. Bought a 70x40x45 stacker box from Dunelm. BBQ goes in that, means we can stack other stuff on top of that and there’s space in the box for wire brushes, cooking utensils etc. keeps it all together.
I bought some aluminium square cross-section tubing on-line. You can buy all the fixings (push fit) and make your own racking to suit. It works for me and utilises most of the space. The trouble with plastic crates (and I do use them as well) is you always require what’s in the bottom one.hi ,,having a big garage is great, first time away with it, i found myself just throwing everything in ,,but has anyone got ideas about good loading methods how to use the space better ,,thanks
We must have gone to the same school! My method is very similar:It's a 7 step process.
You might as well start packing the garage as nobody else will come up with anywhere near as good a solution as this!
- When the garage is totally empty layout everything you are planning to take with you on the ground.
- Put half of the stuff back in the house.
- Move the remaining stuff around a bit.
- Now put half of it back in the house.
- Put what's left on the gound into the garage.
- When you return from your trip take the half of the stuff you packed and didn't use out.
- You have now packed the garage correctly.
hi the question was how to load it ,not how much you can get in it ,,Surely the first question you should be asking is what is the garage payload? The larger the overhang the less payload you have. Just because it's large doesn't mean it can be stuffed full of all your goodies & gear.
Well yeah but the OP has a pilote G740 which if not up plated only has a 450kg - 550KG payload. My F Line has more than that but still only 150KG in the garage. It's not a RS RV like your beauty.I largely agree, but it does depend on the Motorhome.. Large overhangs can have huge payloads too!![]()
And weight is a critical factor……..and where you put that weight….as Johnno was kindly bothering to advise you….hi the question was how to load it ,not how much you can get in it ,,
hi thanks just had it up plated to 3960kg so should have 850kg pay load ,,i thinkWell yeah but the OP has a pilote G740 which if not up plated only has a 450kg - 550KG payload. My F Line has more than that but still only 150KG in the garage. It's not a RS RV like your beauty.
