Light warning light on dash.
5th Wheel
2007 Hymer B class / Ducato 3.0
First run out in new to us van and I get a warning light on dash. Fiat manual is saying exterior bulb blown.......or about to blow. Cheers, last bits handy! 🤣 Checked all lights but all seems working? Any ideas please chaps?
Ta👍
Chesterfield, UK
autocruise Rhythm
Most of my life in one form or another
As above , if nothing has blown its more than likely corrosion in one of the bulb sockets.. systematically remove bulbs and clean everything up.
Had the same in ours
zaskar
5th Wheel
Brilliant! Thanks so much guys. Got a week at destination to check each socket. Good call on the number plate light. Forgot to check that but I do know "Henry"s had an advisory 2 years running on that and dealer reconed he'd sorted it. I'll see when we stop for the night tonight.
Thanks all 👍
zaskar
5th Wheel
Thanks all 👍
Ps. How peed off am I sat here typing this when Mrs Zaskar is having a ball driving us up the M6........ It's MY toy ,🤣🤣🤣
meanders
Funster - Life Member
Ipswich, Suffolk
Eura Mobil Terrestra
Call in at a Toolstation or Screwfix or similar to get Contact Cleaner if you do not already have some.
Telford
A class Pilote
Is there some issues with fitting LED’s that the system cannot recognise and thinks there is a duff bulb. Maybe someone has fitted some LED’s?
zaskar
5th Wheel
RESOLVED. Following your advice (thanks guys) I removed each and every bulb for a clean / squirt of the good stuff. Although suspecting a rear light cluster as I had a similar problem on my 5th wheel, I started with marker lights, then side yellow lights and eventually rear clusters. Soon as I cleaned up the rear R/H cluster, the warning light went out. Not a hard job, just time consuming but satisfying.
Incidentally, based on past experience, I used Wurth 2040 on all the bulbs and fittings as that is what cured my 5ver. (y)
