LHD or RHD lights (1 Viewer)
Dec 1, 2020
223
307
Brassempouy, south west France
Hymer B878 SL
Since Feb 2020
It's apparent that many funsters prefer left hand drive vans to right hand drive. However, if you buy a new LHD van in the UK does it come with headlights that dip left or right? Similar question for tail lights, as reversing light and single high intensity fog light (if there's only one fitted) need to be on the opposite side to UK.
43,802
53,121
Many new vans, if not all, come with a flat beam.... No kick up either way.
As for tail lights... I have a trailer, built in one of the east european countries, with a cert of uk conformity.
The fog and reverse are on the wrong sides and should be the other way round to comply with uk law.
Infact im sure if theres only one fog light it should be central. .
MichaelT
3,914
8,253
Colchester
Carthago I 143 LE
Since 2016
I would say it has to comply with UK law/standards in all respects.
10,157
34,635
sleights
c class
As for tail lights... I have a trailer, built in one of the east european companies, with a cert of uk conformity.
I thought a single foglight should be on the offside. It would be very easy to wire from the existing one and cut that off.
11,654
19,194
HYMER B644
So they should, they can be a nightmare to change
779
2,329
Buckinghamshire
Globecar
My understanding is that in order for it to be registered it needs to be compliant in all respects.
I have a LHD PVC which was first registered (by another owner) in Spain before being imported here and registered in the UK. I add Eurolites stickers for driving on the continent.
Conversely, I have a RHD car in Portugal which was 'matriculated' there. The process entailed replacing the headlights with ones that were compliant for driving on the right.
653
1,990
Hymer ML-t 580 4x4
Getting there!
My new LHD Sprinter Cab Hymer MLt has flat beams LEDs. That said the part number for the headlights is different to the part number for the RHD LED headlights in my last Sprinter.
They are freakishly bright though!
I reckon if you order LHD you will get LHD headlights. If they LED they should be flat beam and fine.
20,102
33,395
Ours is LHD but built to UK spec so 3 pin sockets and left dipping lights.
653
1,990
Hymer ML-t 580 4x4
Getting there!
I've just got the UK Type Approval for mine as part of the registration process.
I just needed to prove, by way of a letter from my local garage, the following points ...
Headlights
The vehicle has Original factory fitted flat-beam LED headlights.
Speedometer
The existing digital speedometer is, permanently, re-programmed, through a standard feature of the vehicle, to display the vehicle speed in miles per hour.
Rear Foglight
The vehicle has rear-fog lights fitted as standard on both the rear left and right of the vehicle.
If you want a new LHD buy in Germany, there are deals to be done. Mine came in after all costs, customs fees, travel etc at 21% less than buying in the UK.
1,197
3,127
Europe
A grey one
since 1996
If you are buying a LHD vehicle in UK it should have compliant lights, ans others have mentioned. Incidentally the latest Ducato (LED) do not have flat beams, according to Simon at Adams Morey. You would need beam benders for Europe.
7,408
8,833
Manchester
A class Hymer
Since the 80s
I swapped the reverse light for a rear foglight, so now there's a foglight on both left and right. Then I added two new LED reverse lights, much better for reversing in the dark now.
