Kannon Fodda
- Feb 26, 2019
- 3,290
- 10,274
- Autotrail V-line 540
- I Make Schoolboy Errors!
Probably got a bubble / empty fluid at the clutch end. It's going to need proper bleeding from the clutch end and that needs the tools to get at it and the software to operate the mechanisms.So, broken down again!
The lid was loose on the hydraulic fluid reservoir & some of it must have sloshed out!
I have topped hydraulic fluid up & it's taken about 250/300ml. If I turn ignition on & select gear it goes in and out ok & I can hear hydraulic pump running every few changes. I have done that lots of times to get the oil through & topped the fluid up after the first time.
If I start it in neutral and quickly put it into gear there is a big clunk & it goes in. I can then select neutral afterwards.
If I start it & wait, as soon as I try to select a gear it says 'gear not available'.
I've tried disconnecting the battery & leaving for 30 minutes but just the same.
Any one any ideas please ????????
