OP here. Just as a follow-up to my query and posts back in March of this year: I decided eventually to bite the bullet and take the MH to the great guys at Offgrid Power Solutions. There the pair of AGMs were replaced with a single 280Ah Fogstar Drift lithium battery. Everything was rewired, including the Victron 1200VA inverter, and a Victron Orion XS 50A DC-DC charger was added. All done to a very high standard.
Interestingly, this did not address the issue with the hairdrier. As before, the drier will run OK on the first setting but then when switching to the next, slightly hotter setting the inverter cuts out after a couple of seconds. I've since added a Bluetooth dongle to the inverter so I can monitor events in the Victron app. It indicates overload when the second heat setting is selected. The conclusion is that the hair drier manufacturer didn't give the full story when quoting wattage and current draw. However, the strange thing is that the drier only draws 39 amps on its lowest setting (which is quite warm rather than cool) so the next heat setting must draw a lot more current to trip the inverter - or the inverter is faulty*.
The good news is that the boss finds the first, fairly warm, setting of the drier to be quite adequate to dry her hair so I'm not going to fret over the lack of higher heat settings.
FWIW I am totally happy with the outcome of the work carried out by Offgrid regardless of hair drier performance.
* The inverter works fine with an electric kettle, a toaster and various battery chargers so doesn't appear to be faulty.
