Insulating an oven - what to use? (2 Viewers)
33,517
69,686
I know there was a thread on here about an oven not being great and some people suggested putting insulation round it, can anyone tell me what insulation type I'd need as I'd like to do mine and don't want to end up with an indoor bonfire! :oops:
Dec 19, 2020
3,962
10,721
The salty bit of Hampshire
Since 2017
Let me know how you get on doing that as I've thought about it for mine. I may as well let you climb the 'steep learning curve'. ;)
5,573
23,084
Cumbria
The fibres from some of those ceramic refractory blankets can be a bit nasty if breathed in. Probably ok once fitted, but best wear a dust mask when cutting it to size.
You can buy a "rigidizer" ( just be careful if you Google it !) which you spray onto the blanket and it holds the fibres securely in place.
2,200
2,930
Hymer B544
2001 Caravans 2011 Motorhomes
I wore a mask and gloves when I was cutting it to shape.
33,517
69,686
There's various types of this ceramic stuff, does it need the aluminium one one side or not at all?
33,517
69,686
Next question, what thickness?
4,687
58,014
Surrey
Carthago C Tourer
I think I remember Lenny HB insulated one of his Tech Tower Ovens years back using some sort of ceramic fibre board which he cut to size. I think he was more concerned about the excessive heat produced above the oven, not just the performance of the oven itself.
I have to say, it sure gets hot up there, one of the reasons, but not the main one, that we don't use our oven very often, except for warming up the odd Pizza or pie, I just don't trust the the thermometer settings, even pre warming you can forget the usual cook times also.
PS: I will never forget what a dealer sales guy said to me years ago now, but still true Quote: They are nothing like as good as your home oven, you gotta remember this is camping gear after all!:rolleyes:
His best ever quote was: Compared with an Alde wet heating system, warm air types are just fan heaters in biscuit tins!:LOL:
I have to agree with him unfortunately, its Funny the things you remember all your life isn't it.
LES
meanders
Funster - Life Member
3,238
11,459
Ipswich, Suffolk
The stuff I used was about an inch thick, and yes, was double sided aluminium. It's quite compressible to slot down the sides. Don't put it down the back... Or at least, I didn't. It's not combustible. But I didn't want to block the air low when running on gas.
Two on Tour
10,824
56,030
Elddis Autoquest 175
I also made up a slab of the ceramic insulation which sits in the bottom of our grill as our oven is below our grill with no insulation between the two, so the oven heat was bleeding through to the grill above. We just remove the slab of insulation when we use the grill.
9,834
26,156
Derbyshire
Elddis Accordo 105
since 2014
I think the insulation I used was 25mm. No foil on it, I used 50mm foil duct tape to hold it on but don't know if that's dropped off by now, must be going on 10 years ago. I had a thought earlier you can wrap chicken wire round it to hold it on šŸ‘
2,850
2,293
Northampton
Rapido & Bongone
i USED A SOLId ceramic/cement board from B&Q about 4mm thick. cant remember name and its not on the offcut i got left. Used a jig saw to cut fresh blade each cut. Easy to use and did the job in thermaly issolating wood pannels next to oven. used to get really hot.
