denisejoe
looks that a lot of the interior would have to be removed to repair the water damage may even be a body off job
It must be coming in via the wheel arch liner seal just hoping that if you get wet weather on the drive back it doesn't come in from the road spray underneath as the trim you have sealed I'm fairly certain is only a cosmetic trim.View attachment 264675 Well it may not look very pretty but the tape is doing it’s job while van is parked up. We have had thunderstorms and very heavy rain for 6 hours or more and no ingress of water.
Could just mean all effected ones or could be referring to inner and the outer trim. Or even a translation error from Germany.Hi Lenny, interesting he says “all” wheel arches need to be removed, maybe it’s a typo?
Doesn't mean Hymer can't supply the part not rocket science to cut a bit timber to size Hymer will have a drawing on file for it.Have just queried it with my dealer and stated my displeasure that the wooden sides and back panel cannot be found on their parts screen. They will need replacing I can push easily push my finger into the corner of the back panel
Probably not on the dealers parts list because not a part expected to need replacing.
It is but I would be a lot out of pocket cancelling the booking.Such a shame you were unable to change your ferry, and go home via Bad Waldsee. You could have got the Hull ferry home from Zeebrugge or Rotterdam - an easy drive from Bad Waldsee, and could have had it all sorted, by the time you got home.
Very trustingCould it be rain water getting in via the garage door seals? I had this problem on my 2003 B Star-line. I only tracked it down by shutting myself in the garage and get my wife to direct a hose at and around the garage door. My solution was to add additional sealing around the door. I used rubber draught-proofing strip. So far, so good
I think, if you amend our booking more than 5 days in advance you only suffer an amendment fee of around £15. You could amend it to a return crossing for your next visit to Spain.http://www.brittany-ferries.co.uk/faq/amendments-cancellations/how-can-i-change-my-holiday-booking
Ours leaked, through a bit a hardened sealant but because it is an ‘exalted Hymer’ it suffered no damage whatsoeverSurely an exalted Hymer does not leak, you must all be mistaken![]()
