Hymer Conversion to Lithium (7 Viewers)
Feb 22, 2023
47
107
Hymer BMLi880
Owned a MH since 2012
Decided to 'bite the bullet' and replace my version of the Hymer 'Smart' Battery system with a full blown lithium set-up. Reason: I have an issue with one of the AGMs and whilst the system has generally served me well it seems pointless to buy 3 new AGMs when there are lots of cost effective lithium alternatives. Just wanted to run my plans past those with more technical knowledge or experience of similar:
Fit 2 x 230Ah LifePO4 Batteries
Change EBL settings to Lithium profile via the control panel - this will enable me to continue using the charging module (20A).
Remove the two auxiliary chargers (LAS 1218 & LAS1218 BUS) as neither has a lithium setting.
Fit a new mains charger to work alongside the EBL module (50A).
Replace Schaudt LRM1218 Solar Regulator with a Votronic one with lithium profile. (currently have 240w of solar but may well add another 200w to this after the winter - so I could go large with the new MPPT in anticipation of this increase in size).
Fit a votronic computer and votronic solar monitor.
Inverter to stay - normal factory fitted Dometic 1800w.
Everything else eg, cables etc seems to be fine.
Any observations / suggestions welcome.
Buddy1012
Feb 22, 2023
47
107
Hymer BMLi880
Thanks for that - that's useful. I've had a totally Victron enabled house for few years so well versed in the reliability and robustness of the kit.
Buddy1012
Feb 22, 2023
47
107
Hymer BMLi880
Fit a Victron solar controller as the Votronic one you would need is the 430 there have been problems with them with Lithium.
On the solar side - would it be okay to keep any new panels completely separate and use one smaller MPPT for the existing panels and keep this via the EBL and then fit another MPPT and additional solar panels directly to the leisure batteries? (The existing route via the EBL would take care of the cab battery connection without the need to route an additional cable through from the 2nd MPPT).
9,192
20,587
Salisbury
Hymer B678DL A class
I have done our Hymer conversion myself and left the two existing solar panels controlled by the existing buttner controller as it does a good job I then added another 240 watts of solar using a Victron smart controller it all works really well in tandem using bus bars and victron multi plus inverter charger.
I actually disconnected EBL from mains but still use it for the 12v circuits.
566
476
4 berth coachbuilt
Our new Hymer Exsis-i 580 came from the factory such that all we had to do was change the battery.
Took out a heavy AGM lead-acid and replaced it with the same physical weight of lithium.
Job done - Five times the usable battery capacity - just for changing three charger settings.
Buddy1012
Feb 22, 2023
47
107
Hymer BMLi880
What year is your MoHo? On mine the two auxiliary chargers are not right for lithium but everything else stacks up eg cabling etc
Buddy1012
Feb 22, 2023
47
107
Hymer BMLi880
On a side not we put a Fogstar 280ah battery in our Hymer as recommended by Offgrid, reason being the 280 has 8000 cycles whereas 230 is only 4000. They said it’s the best cost effective battery, and will be about 300ah in reality, just like the 230ah are about 10% over.
Good choice then - if only I was young enough to take advantage of 8000 full cycles - based on 100 n days away give or take each year I was anticipating that the 4000 cycles would get me up until I’m about a 106 or so 👨🏼‍🦳
97
34
Derbyshire
Hymer BMCi600
Since 2018
That should have a lithium setting
566
476
4 berth coachbuilt
Our Hymer Exsis-i 580 is 2022. It did not have any auxilliary chargers
22
23
Hymer B MC T580
Since 2008
Our 2019 BMC-T580 has a Schaudt WA121545 battery booster, I've set it to the LA setting as the Lithium setting gives a constant 14.4 volts and my Fogstar 280 complains. Another thing to look at is how your fridge is connected for 12v running, ours comes directly from the battery terminal so when mobile on 12v the load on the booster always give the upper voltage of 14.4 and will not reduce to the lower Trickle charge voltage which may cause excessive COVs.
When my battery is about 80 - 85 percent full I use the Fogstar app to turn off charging or turn off the Fridge.
Buddy1012
Feb 22, 2023
47
107
Hymer BMLi880
As part of my swap out I am
now by passing the EBL with a new lithium profile MPPT which doesn’t have dual battery function. Does this mean that I need to fit a Battery Master to take care of the cab battery?
