- Feb 22, 2023
- 106
- 371
- Hymer BMLi880
- Owned a MH since 2012
Decided to 'bite the bullet' and replace my version of the Hymer 'Smart' Battery system with a full blown lithium set-up. Reason: I have an issue with one of the AGMs and whilst the system has generally served me well it seems pointless to buy 3 new AGMs when there are lots of cost effective lithium alternatives. Just wanted to run my plans past those with more technical knowledge or experience of similar:
Fit 2 x 230Ah LifePO4 Batteries
Change EBL settings to Lithium profile via the control panel - this will enable me to continue using the charging module (20A).
Remove the two auxiliary chargers (LAS 1218 & LAS1218 BUS) as neither has a lithium setting.
Fit a new mains charger to work alongside the EBL module (50A).
Replace Schaudt LRM1218 Solar Regulator with a Votronic one with lithium profile. (currently have 240w of solar but may well add another 200w to this after the winter - so I could go large with the new MPPT in anticipation of this increase in size).
Fit a votronic computer and votronic solar monitor.
Inverter to stay - normal factory fitted Dometic 1800w.
Everything else eg, cables etc seems to be fine.
Any observations / suggestions welcome.
