- Feb 22, 2011
- 11,453
- 25,306
- Hymer B544 A Class
- Since 2015
Similar to what I was thinking but I would get the corner of the van closer to the wall, a vertical timber against the van and a scissor jack between the timber and wall. This way you can better control the movement and also, if necessary, change the angle/direction of push. Leave the jack in place until adhesive has cured. I, also, think it’s as a result of accident damage.I'd clean out the joint, position the side of the van say 4' from a brick wall, fill joint with sikaflex (if it's just the trim that's loose), plank stood up against the trim and brace it off the wall with a bit more timber until the gap closed and leave to set.... a morning's work at most, £20 in materials
£2500 and no guarantee? - they're having a laugh
Try Nick Bolton, he is just outside Banbury. Really helpful.I am minded to get a couple of quotes.. any recommendations of places within 50 miles of Oxford ?
TIA
It's not the sealant that you refer to, nor is the sealant in your link above, the right stuff to use........unfortunately. Products from Sika or Wurth, which are bonding adhesives are the way to go.I think it just the old sealant drying out, as it does on the roof lights.
Why not do it yourself.
90 miles from Oxford, but Cannock Resprays have a very good reputation. You could, at least, discuss it with them over the phone.
The rain gutter on ours came away from the body at the lower front of the MH. Deespite my insistence that I wanted Sikaflex, I was persuaded by Pioneer Caravans that I needed a non setting mastic sealant. I ended up doing the job twice, but once I used the correct bonding adhesive, the job was a good un.
Hymer used to use a product called Kurapop. I now use a bonding adhesive called Puraflex 40 from Toolstation, which is manufactured by Sika.
It came well recommended by @Terry, and I have used it with great success.
I'm with others, ie, line it up alongside a wall, gouge out and clean the joint and rain gutter surfaces, fill with bonding adhesive, bed in the gutter to seal, prop and jam firmly between the wall............down the complete lenght of the gutter rail, and leave to set for 12-24 hrs, then clean off any excess.
In the absence of Peter Hambilton of Preston, Tim Curry near Stratford is your next best independent Hymer repairer...................but that looks like a DIY job to me.
Good luck.
Jock.![]()
What he said ^^^^^^^^^^I'd clean out the joint, position the side of the van say 4' from a brick wall, fill joint with sikaflex (if it's just the trim that's loose), plank stood up against the trim and brace it off the wall with a bit more timber until the gap closed and leave to set.... a morning's work at most, £20 in materials
Have you tried Complete Caravan Services just north of Oxford?
I’m not recommending them but a quick search brought them up. It doesn’t have to be a specific Motorhome repairer. All our work is done by FM Caravans in Hull. Same skills/tools.
Do you have contact details for Tim Curry please..
i would do the sameI would scrape that joint out, dry it throughly and fill it with sikaflex and clamp it back together.... fixed...![]()
Yes .. I'm owning up to a German van with damp.
So all you British van owners gather around... get a comfy seat...pour yourself a glass of Bombardier bitter, Wadsworth 6X or any non lager drink...
Bring your cheddar/Wensleydale or other quintessential English cheese to room temperature, open a pack of Jacobs cream crackers , take the lid off the butter dish and settle down to read about my woes...feel the cockles of your heart start to warm... because here we go...
I am the owner of a 1999 Hymer B584.. I have owned and loved it for the last 3 years, it has Wild camper options ...solar panel and two gaslow bottles.
Over winter I haven't been away much but every week I take it for a 20 mile run.
On returning from a run in March View attachment 304461 I noticed that the passenger side wall had detached from the rear wall...see pics..
I took van to a Midlands motorhome repairer and asked for an opinion and a quote to repair..
Well.. when a knowledgeable engineer says ' I've never seen that before' ... my heart sunk and I knew I was in trouble..
They suspected damp but advised me that a repair would be starting at £2500 ..could be more and they could not guarantee the repair..
so my options...
1. Trade in with a dealer - Probably no chance or buttons.
2. 2nd opinion ? the workshop are well respected..
3. Advertise on a specialist site and hope a hobbyist wants a challenge.
4.. Tape over the join and just keep it going until another major repair arises.. eg Engine or gearbox failure..
Option 4 is my current choice.
Anyone else have an opinion ?
This is written tongue in cheek and I don't want to upset anyone.
I accept in life sometimes we are lucky.. and sometimes we are unlucky..
Overall in my life I feel I'm in credit.
PS I still love her.. meiner liebling xx
Sorry to dissapoint you but I to have a so called quality German van with damp. My Carthago, which i call the shed, has suffered water ingress to the garage area. It must be a free option now on a lot of german makes
Its bone dry..There is an outside locker under the damage, can you see/feel any rot there ? Try digging your finger nails in.
Whereabouts this time please?Its bone dry..
Updates coming soon ....I'm going for a third opinion on Tuesday..
Good job you took it to the 2nd guy the first one obviously doesn't understand Hymer construction - there aren't battens that can swell, Hymer use the PUAL system for construction.. He's a really nice guy who had a look and said probably a small leak has expanded a batten or two and they have expanded pushing joint out.
