Grianan
Can anyone help me by explaining how a b2b works and why it would be beneficial?
If I am off grid it would be in a place where there are no neighbours, however I would not like anyone near me to fire up a noisy genny, but a lot of smaller gennys do not cause a lot of noiseIf I was off grid enjoying peace and solitude the last thing I would want is some inconsiderate neighbours starting up a generator.
Really interesting to see your results with the lithium batteries please let us know how they performIn my opinion not much, you could add more solar but that's unlikely to give you what you want at this time of the year.
Our PVC had 200W of solar and two 95 Ah AGM batteries. Last October in the lakes we lasted just over two days, compressor fridge and diesel heating.
We go back to the lakes next week for a few days now with two 95Ah lithium batteries and it will be interesting to compare performance as weather conditions are expected to be similar i.e no sun and plenty of rain.
In the summer months with the obvious solar gain we had no problems off grid, infact the lowest reading at the start of each day was 78% of charge remaining and by mid afternoon they were fully charged.
Lithium is expensive and not for every one, if you spend most of your time on four star sites it's probably not necessary but if like us you like nothing better than camping in the middle of a field it totally changes the way you can off grid.
Do look at an under seat battery. My new 200 Ah lithium fitted. Under the passenger seat and was less wide than the 2 old AGM’s. Depth about 1 cm less and height at least 1 cm less. I chose KSEnergy - cracking guy Neal owns. £1200. Roamer do one cheaper but KS give a 10 year warranty.
A lot of Lithium suppliers say they are a drop in replacement. They will work but if you want the best out of them you will need to upgrade your charging sources.Just had a look at the website.
No modifications to my current vehicle or solar system needed, just old batteries out and new in, am I reading that right?![]()
Wind your neck in,
If you don't have a B2B or one with the correct profile you will need one or a new one.
Solar regulator needs the correct charging profile.
And if you use EHU you may need a new mains charger.
Hi KarenLooks a good option for when ours need replacing - which model battery do you have? Would be an easy, effective option to know it just fits in
EDIT Presume it's this one https://www.ksenergy.co.uk/blog/200...ttery-for-the-worlds-most-popular-van-chassis ?
Thank you David - all very helpfulHi Karen
It is the KS-SB 200B. Another great benefit for me was saving 30KG weight. I had underestimated the effect of all those lovely extras that the dealer had ordered! Now with careful pruning or changing what we take we should now be just about within the 3,500 weight.
Neal Morris who owns KS Energy has posted 3 videos on the issue of the possible effect on your alternator of charging the lithium direct. I can follow so much but the detailed calculations rather went over my head. He fitted my battery and from my perspective I was highly relieved.
The issue of the trinity of solar, vehicle and mains charging is complex. In my case I already had a Votronic solar regulator so by good fortune that had a Li setting already. Vehicle charging - Westfalia do not do things by halves but what a lot of work to identify what it has relative to charging etc. It turned out that it already had a heavy duty relay Daimler made that has a capacity of 150 Amps. The Westfalia wiring and also that installed by the German dealer was clearly also judged to be heavyweight.
The Westfalia does not have either an EBL a Sargeant a CBE or anything similar. It does have quite a detailed digital control panel and all the functions survived the new battery - save that I will rely on the Bluetooth App for battery SOC rather than the Westfalia display.
So after installation of the battery, when driving home, I was charging the lithium at between 40 and 46 Amps until the battery neared 14 Amps and the rate steadily throttled back to the point showing only the compressor fridge draw. I had already bought a Votronic 12 12-30 B2B because it is tiny and space under the seat is an issue. After swopping over the new for the old 2 AGM's there is more space and where the solar regulator is stuck to the battery to the right the Votronic should go to the left. So that achieves good air flow through the fold down black plastic rear seat space cover and avoid taking up other hard earned space!
It is probably the case that I do not NEED to fit the B2B or rather have it fitted, but I shall do that. It is likely that the B2B will mostly be throttling back the charge, but I shall feel more comfortable doing that. I would stress for the interest of others that I was quite lucky in the various Westfalia stuff, the wiring and that installed by the German dealer. Ironically the larger Votronic B2B may just have fitted, but my take is that when we drive to see our son in Spain, the extra hours driving will not be here nor there. In any event I gather Lithium may quite like not being fully charged all the time.
The German made mains charger is geared to AGM but the firm said they could "reprogramme a profile" for lithium - cost reasonable but shipping and handling would make it more costly. If we ever go to Germany maybe we will have that done. The rate of charge was checked and found acceptable but my take is that if as I suspect, we keep the lithium battery charged above 75% why bother with mains anyway? The sense of freedom form that cable is great! If we did use mains I would disconnect if the charge got over say 90%.
The Votronic 1500 inverter will probably be better served as well. Almost all this stuff has over under and all in between safety cut-off.
So provide you research your own van and the various aspects lithium has huge benefits in my view. Cost to date around £1,700 plus fitting B2B to come. I got £23 for the old batteries from a scrapie!
Happy to continue here or PM - 10 year warranty on battery too!
Thanks Richard, with my level of expertise (nil) I need someone who can do the complete job so appreciate the recommendation. Would you mind letting me know (here or pm) cost? Thanks LizWe had our lithium conversion done by RoadPro who fitted a complete system including B2B, battery management and small screen to monitor the whole thing.
The B2B whacks in something like 40+amps when we start driving.
I know there are cheaper options but having it all done by professionals was simple and you know it will be a good job.
Other similar companies are available!
Richard.
In an ideal world but these days its very rare to find a wild spot with no other vans or indeed houses nearby ....yes there are some of course but usually anywhere nice to stop there are others doing the same thing not far from you ...ive noticed anywhere ive been parked that anyone firing up a genny is generally not well received even the alleged quiet running ones aren't that quiet when you're away from noisy towns etc ....the drone csn often be carried for milesIf I am off grid it would be in a place where there are no neighbours, however I would not like anyone near me to fire up a noisy genny, but a lot of smaller gennys do not cause a lot of noise
So that is interesting. We saw these used on boats. I wonder if anyone has used on a camper?How about a wind turbine?
Compliments the solar power?
Cheers James![]()
600w DC 12v 5 Blades Lantern Wind Turbine Generator Vertical Axis W/ Controller for sale online | eBay
Find many great new & used options and get the best deals for 600w DC 12v 5 Blades Lantern Wind Turbine Generator Vertical Axis W/ Controller at the best online prices at eBay! Free delivery for many products!www.ebay.co.uk
OK this is embarrassing. It’s under driver seat along with both leisure batteries but no idea what it is and no way of seeing how much we’re generating other than battery Indictator goes green from orange when it’s sunny off grid.The one thing not mentioned is your solar controller- is it MPPT? If no you should consider replacing it and when getting a new one make sure it is lithium compatible.
I would stay with the compressor fridge in your situation.
That's why mobile phones have cameras ... saves you trying to get your head down there to see what it says!OK this is embarrassing. It’s under driver seat along with both leisure batteries but no idea what it is and no way of seeing how much we’re generating other than battery Indictator goes green from orange when it’s sunny off grid.
DO what we did,Can anyone help me by explaining how a b2b works and why it would be beneficial?
Just be sure it's small enough to take inside.So that is interesting. We saw these used on boats. I wonder if anyone has used on a camper?
can be noisier than genniesSo that is interesting. We saw these used on boats. I wonder if anyone has used on a camper?
I suspect that it is a PWM controller if you don't know as dealers will fit the cheapest that they can get away with. But try to use your camera as per Minxy Girl but don't drop it ( although taking the seat off was less difficult than I thought it would be) ! If fitted by Globecar it might be a MPPT.OK this is embarrassing. It’s under driver seat along with both leisure batteries but no idea what it is and no way of seeing how much we’re generating other than battery Indictator goes green from orange when it’s sunny off grid.
But that's the point surely. Stuff defrosting is a potential disaster, especially if you eat meatStuff melting in the fridge was the only issue.
