JockandRita
- Aug 2, 2007
- 12,688
- 174,652
- N+B Flair 8000i
- Since May 05 (Ex Tuggers).
I did Martin, and yes, the AES light was illuminated on the solar regulator. I stayed with it for 5 x minutes pulling almost 16A. I had to go out, so shut everything down to prevent an unnecessary discharge, but I will check it out again. One theory is that it is sensing over voltage, (as the batteries were on charge prior to EHU disconnection), and should switch to gas one the voltage drops a little.Hi Jock
On AES it should only go to 12v with a D+ signal, if it is still doing it have a look and see if the AES light is on on the regulator, if it is it should only stay on 12v for 30 minutes and then go to and stay on gas unless as you say there is loads of sun,
Martin
30 x minutes pulling 16A seems a long time.
Sorry to go off subject Jon.
On the advice of Lenny, I purchased a clamp meter, which certainly makes easier, the job of knowing the amount of charge/discharge, and appears to be more accurate than the CBE display.
Some of the Sterling Power Product videos on YouTube, by the man himself, are very interesting and informative, eg, B2B vs Alternator, Lithium vs AGM, Pb Acid/Pb Crystal, etc.
Cheers,
Jock.
