- May 3, 2022
- 67
- 49
- Adria Compact DL
I use one of these with a hole in the side so one of the ends can be pushed through it and secured with Velcro. It works well.I’ve used one of these for last 10 years and by found it to work really well.
Amazon product ASIN B008OTE8DY
Where in Cornwall?I have two 25m ones going for free if anyone’s passing by in Cornwall….![]()
I use one like thisI have 25m very heavy orange cable =- can anyone recommend a cable reel that is EASY to wind up? Have got two and both are incredibly difficult and awkward to wind with pathetic handle.![]()
Found these terrible. so heavy and hard to use. Would recommend against.I’ve used one of these for last 10 years and by found it to work really well.
True, but the longer you get, the fewer times you will come up short.Whatever length you buy, eventually it will be a metre shorter than you need.
^^^ this, tbh when we have to join ours together just raise off ground using tent pegs so they dont sit in a puddle. We use them in all conditions no issues just make sure they have the gasket fitted and/or use MK etc.This has no IP rating, so no guarantee of any standard at all. The spec says it's 'Splashproof'. There's not really anything that is 'waterproof', just various levels of protection, from 'splashproof' to 'submerged to 100m depth'
The round blue connectors are weatherproof, rated IP44 which is 'splashes from any direction'. I see nothing that says these protective boxes are any better. There are literally millions of these blue connectors in use throughout UK and Europe, in all weathers. They won't stand being actually submerged, but apart from that they are fine in all weathers.
