- May 3, 2022
- 67
- 49
- Adria Compact DL
Just out of curiosity, did I read somewhere that you don’t need to worry about polarity with an EU manufactured Motorhome because it has circuit breakers on both Positive and Negative wires - which is not the case with UK manufactured vans which only have a breaker on the Positive?
I, too, have a polarity switching lead, tester, etc. I never actually used the polarity switching lead because on the occasions with reversed polarity that I encountered, these were all fed from EU EHU supplies using the ‘2 central pin and edge earth’ type connections. I simply turned the 2 pin plug through 180 degrees to give the correct polarity.
I don't use a cable reel, instead I loosely coil mine into a plastic box. It takes up a little more room than a reel, though.I have 25m very heavy orange cable =- can anyone recommend a cable reel that is EASY to wind up? Have got two and both are incredibly difficult and awkward to wind with pathetic handle.![]()
problem is thick, orange and in the cold it doesn't exactly coil easilyI don't use a cable reel, instead I loosely coil mine into a plastic box. It takes up a little more room than a reel, though.
Not always true. I have an Autotrail Apache 2010. One of the circuit breakers went and I had quit a time finding the required double-pole breaker to replace it.did I read somewhere that you don’t need to worry about polarity with an EU manufactured Motorhome because it has circuit breakers on both Positive and Negative wires - which is not the case with UK manufactured vans which only have a breaker on the Positive?
I also happened to take my 3 pin uk connector, which came in handy when visiting a friend who now lives in Spain. His extension which I had to us was a UK type........you never know what you might need on your travelsView attachment 711246 You may Need one these in abroad 230v to euro connector
Crumbs.I carry two 25m cakes and all the adapters
Cakes! Now your talking... I always carry a few Cakes.I carry two 25m cakes and all the adapters
But I've no cables
I have this - really difficult, hard to turn and very heavy with the cable I have but thanks anywayI’ve used one of these for last 10 years and by found it to work really well.
Amazon product ASIN B008OTE8DY
you need have of that just to get from one end of your mansion on wheels to the other !We carry 2 x 25m. Have had cause to use the two together on occasion![]()
Easier just to coil loose cable. Once you've figured out that it remembers it's original coils it's easy.I have 25m very heavy orange cable =- can anyone recommend a cable reel that is EASY to wind up? Have got two and both are incredibly difficult and awkward to wind with pathetic handle.![]()
Not so easy in frosty conditions. It's like trying to roll draining rods.Easier just to coil loose cable. Once you've figured out that it remembers it's original coils it's easy.
Use the 'blue' stuff. I've never had trouble with the orange though.Not so easy in frosty conditions. It's like trying to roll draining rods.
Thanks , just ordered one . Struggled trying to roll mine up today on site !I’ve used one of these for last 10 years and by found it to work really well.
Recently purchased a cable reel off of Amazon for 12 quid and looked at it so far. Says it can take 30 metres and it is wind up.I have 25m very heavy orange cable =- can anyone recommend a cable reel that is EASY to wind up? Have got two and both are incredibly difficult and awkward to wind with pathetic handle.![]()
