Hooking up at home.
skyetripper
Northumberland
Van Conversion
Just out of interest, what do most people do to hook up at home (as, when and if needed)?
Going to get an electrician to put an outside socket on the side of the garage, but wondering whether to just fit a normal domestic socket and use a fly lead, or fit an EHU type of socket while he’s on.
This is what I have on the outside of my garage:
It also gives me an external 13A socket. Inside the garage it runs through an isolation switch so that it cannot be used whilst I am away.
Works well (y)
If you pull the plug, that also stops the starter battery being topped up. However if instead you remove the 'Internes Lademodul' fuse, that stops the leisure battery charging, but keeps the starter battery top up active.
autorouter , same advise if a separate dedicated lithium charger is fitted for a replacement Lithium under seat battery? I was looking to splice into the 240v feed for the EBL as the supply for the separate charger.
Sorry for crashing the thread.
Regards.
Mike.
We had assumed wrongly that the EHU would keep the starter battery topped up.
Plugged my MH into the EHU yesterday afternoon. The Swift Command panel was showing the charge was being fed direct to the leisure battery. Went back to check on things this morning and the panel showed the LB as full and the hook up was now charging the vehicle battery. My vehicle is a 2019 Swift compact C205.
