Totally agree. Truma actually have the cheek to refer to the plastic case as thermal insulation. I think in this age of conservation and energy efficiency Truma should do much better with this aspect of their heaters.What's this super water heater have you got?
A Truma Combi only keeps the water warm for a couple of hours
How are you going to get on when we all go to electric vehicles?Kinda jealous of you lot with a drive, if I can park my van in my street (residents parking) I rarely can outside the house (2hour parking restriction), if I get that lucky it’s a hookup out the upstairs bedroom window thru the roof vent (to stop the pedestrians tripping on the cable &/or it getting stolen, by the time I’ve rigged it up I can just about get the hoovering done & it’s time to move it again
Sell the bloody house, the van is a money pit I want to get something back out of it!!How are you going to get on when we all go to electric vehicles?
Geoff
That's exactly what I've got too, plugged into an outside socket I had fitted, which is switched from inside the house. I originally planned to have a camper socket, but changed my mind and fitted a twin three-pin socket as it's more flexible. The van is plugged in whenever I'm home, but it's only 'switched on' once a week, unless I'm going away and am cooling the fridge in advance. Having a dedicated lead for home use saves messing about with my regular hook up cable.I just made up a dedicated lead, domestic plug one end and camper plug the other end with 10m of spare flex. Cost me about £10.
Totally off topic but we have just had a sunday lunch with a bottle of wine (the wine was £16.60) at the Wanderer bistro on Knaresborough CMC and a couple sat near us and ordered a bottle of wine and when the waiter said £16.60 he in a loud voice uttered HOW MUCHHOW MUCH !!!!!![]()
Move!Kinda jealous of you lot with a drive, if I can park my van in my street (residents parking) I rarely can outside the house (2hour parking restriction), if I get that lucky it’s a hookup out the upstairs bedroom window thru the roof vent (to stop the pedestrians tripping on the cable &/or it getting stolen, by the time I’ve rigged it up I can just about get the hoovering done & it’s time to move it again
The fish and chips are nice from there we took them back to the van, lovely quality just not enough.Totally off topic but we have just had a sunday lunch with a bottle of wine (the wine was £16.60) at the Wanderer bistro on Knaresborough CMC and a couple sat near us and ordered a bottle of wine and when the waiter said £16.60 he in a loud voice uttered HOW MUCH,must have been a yorkie
.......We had assumed wrongly that the EHU would keep the starter battery topped up......
That's what I thought mine is supposed to do but it's actually not keeping the vehicle battery topped up so it's on my list to get checked!Does it not do that then or would that be manufacturer dependent?
I have a Swift Escape Compact C205 and im sure I was told on the hand over that the charging system automatically switches between the leisure and engine batteries when the EHU was plugged in...
If you pull the plug, that also stops the starter battery being topped up. However if instead you remove the 'Internes Lademodul' fuse, that stops the leisure battery charging, but keeps the starter battery top up active.Having just fitted LiFePO4 leisure batteries I pull the plug on the charging circuit (Shaudt EBL99) as I understand they are give better life if kept at only 50/60% charged when not in use, it's easily accessable under the front seat.
Good point and good info as well. I use my motorhome on a weekly basis usually, a 12 mile round trip to a supermarket just to give the mechanicals a work-out so hopefully the starter battery will be getting topped up from this.If you pull the plug, that also stops the starter battery being topped up. However if instead you remove the 'Internes Lademodul' fuse, that stops the leisure battery charging, but keeps the starter battery top up active.
Do your batteries have Bluetooth and a phone app?Good point and good info as well. I use my motorhome on a weekly basis usually, a 12 mile round trip to a supermarket just to give the mechanicals a work-out so hopefully the starter battery will be getting topped up from this.
Incidently, I had the EBL99 converted to charge LiFePO4's correctly, but of course this would mean that on EHU at home they would be charged to 100% all the time.
After thinking about your info regarding the 'Internes Lademodel' fuse, I may look into making up an external switch incorporating a suitable amp rated fuse, and wire it in place of the 'internes lademodel' fuse to give me a conveniently located switch instead of pulling the fuse each time ( as long as I remember to switch it back on each time of course)
No bluetooth or app, just standard Ecoworthy LiFePO4Do your batteries have Bluetooth and a phone app?
Can you turn off charging with it?
