- Jul 28, 2010
- 15,475
- 20,773
- Rapido 7090F 3 litre 160
- May 2010
Yes
Total 7000 is the semi synthetic
Link Removed
Link Removed
Is that fully Synthetic??
Synthetic technology multigrade
Anyway, when you put oil in an engine I was always under the impression that as soon as you take it round the block it goes black so even if you took it out immediately it would look 'bad' so how can you tell the difference between oil that's been drained after a very short period of being in the engine and that which has been in for say 2 years?
This puts my mind at ease , as when we purchased our MH from a dealer they serviced it, ( well got the garage locally to service it ) , when we got it home after a few days i checked the oil level and the oil was as black as your boots.. but yet obviously you could see there had been a new oil filter fitted to it , so i'd be pretty sure the oil would also of been changed.when you put oil in an engine I was always under the impression that as soon as you take it round the block it goes black so even if you took it out immediately it would look 'bad' so how can you tell the difference between oil that's been drained after a very short period of being in the engine and that which has been in for say 2 years?
You say the van is only 18 months old, should have had an oil change and fluid check at 12 months. How was the coolant level then?
Both wrong on an imported vehicle first service is due at 45000km regardless of age but they recommend checking belts & brakes at 2 year intervals.The service interval is up to 2 years on newer ones.
I'm not saying the manufacturer recommends it or otherwise, the fluids should be checked and the oil changed because it's a good thing to do. (actually read the handbook, it probably recommends a fluid check every week).Both wrong on an imported vehicle first service is due at 45000km regardless of age but they recommend checking belts & brakes at 2 year intervals.
Errrrr .... don't Fiat make engines any more? I know the bigger ones used to come from Iveco, but always though the 2.3s were made by Fiat, or rather their subsidiary.Fiat are only passing on what the engine manufacturer has told them
What ever.. I am sorry but I will still stick with believing what manufacturers of modern engines tell me ( and that I have personal experience of as being correct )..Fiat are only passing on what the engine manufacturer has told them, probably the spec that Fiat gave them a few years ago. I, and many others, will continue to change our oil every year, we believe it is good for the engine, not detrimental as suggested. Modern oils may be very sophisticated, diesel engines still operate on the same principles so the oil gets dirty, holds metal and combustion particles, and the filter loses it's efficiency and drops the oil pressure.
Iveco is totally owned by Fiat and the 2.3 is an Iveco engine.Errrrr .... don't Fiat make engines any more? I know the bigger ones used to come from Iveco, but always though the 2.3s were made by Fiat, or rather their subsidiary.
I do not think it is that simple any more Lenny.Iveco is totally owned by Fiat and the 2.3 is an Iveco engine.
If you read carefully you'll see I said "UP TO" 2 years ...Both wrong on an imported vehicle first service is due at 45000km regardless of age but they recommend checking belts & brakes at 2 year intervals.
And I said years has nothing too do with it, on an imported vehichle, but you do get stitched up on UK supplied ones.View attachment 138473
????And I said years has nothing too do with it, on an imported vehichle, but you do get stitched up on UK supplied ones.![]()
Service interval on imported vehicles is only given as a mileage.????
Noticed the coolant level is below min marker... Moho is 18mths old so not due for any kind of dealer/Fiat service...
It's been a long time since I faffed with engines, having had company cars for the last 25yrs of working life...
Apart from having to be a Gynaecologist to do anything on A Class engines.... Does one need to use "special" fluid or particular anitfreeze nowadays?... the liquid in tank is pink..
Or can I just top up with water like we used to do many years ago?
http://www.motorhomefun.co.uk/forum/threads/this-week-i-bought.45103/page-251#post-2156018What's wrong with your headlights?
