So what do you do with the bag of soggy contaminated grass?
Geoff
![Not sure about that :unsure: :unsure:](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f914.png)
Geoff
Throw it under hedgerowSo what do you do with the bag of soggy contaminated grass?![]()
Geoff
Bit of a con really, I can see that blocking all the way up to the shower tray, then some very smelly over flowing.Re:an advert seen in Camping and Caravanning Magazine May 2023.
The essence is that you drain your grey water through a filter direct into the ground (not onto the ground). I'm not convinced, and would sites allow it? Anybody tried one?![]()
Caravan Grey Water Disposal System | Mac Products
Mac Products bring you the Grey water disposal system that's easy to clean and with no need for a grey water container or caddy. find out more today.www.greywaterdisposal.com
Only if you fill your entire grey tank first. There's quite a bit of buffer.Bit of a con really, I can see that blocking all the way up to the shower tray, then some very smelly over flowing.
No more so than bin bags left outside motorhomes overnight and overflowing bins. It would also be in such a small quantity due to a filter. In comparison to the mountains of waste around the UK feeding urban foxes, rats etc I personally don't see a problem with filtered water being discharged into hedgerows.Food waste attracts rodents.
I think this is correct up to a point. However it depends upon the volume and load that is applied to the hedge. For decomposition an area needs oxygen and time. Bug eats the organic matter. However, if you overload the hedge, then the bugs will not be able to do it fast enough because they will not be able to multiply quickly enough and/or they will run out of oxygen. The phenomena is known as biological oxygen demand and is a critical environmental measurement.Grey water does not need filtering before going in a hedge. The tiny amounts of food waste are well diluted and compostable, they will either feed the ground or wildlife.
What about the oil & washing up liquid? most are not good for the environment.Grey water does not need filtering before going in a hedge. The tiny amounts of food waste are well diluted and compostable, they will either feed the ground or wildlife.
We use cooking oil very sparingly but it is biodegradable and most will decompose within 28 days. We always use Ecover washing up liquid which has plant based ingredients and is again biodegradable. Neither will cause harm to the hedges. One CL we visited in Kent asked for all the grey water to be emptied on his newly planted fruit trees, he would not be doing this if it was going to harm them.What about the oil & washing up liquid? most are not good for the environment.
"he would not be doing this if it was going to harm them" well he see in twenty years time if it was a good idea, it is the degreasers that are the problem, they destroy the portective waxy coating on the leaves and roots.We use cooking oil very sparingly but it is biodegradable and most will decompose within 28 days. We always use Ecover washing up liquid which has plant based ingredients and is again biodegradable. Neither will cause harm to the hedges. One CL we visited in Kent asked for all the grey water to be emptied on his newly planted fruit trees, he would not be doing this if it was going to harm them.
Will you visit again in 20 years and report back to FUNWe use cooking oil very sparingly but it is biodegradable and most will decompose within 28 days. We always use Ecover washing up liquid which has plant based ingredients and is again biodegradable. Neither will cause harm to the hedges. One CL we visited in Kent asked for all the grey water to be emptied on his newly planted fruit trees, he would not be doing this if it was going to harm them.
I agree. The odd bit wont harm but it would not be good to use water with detergents in for any sustained period or in great volume. The degreasers have an element of biodegradability. It will be very slow though, like it is with oil."he would not be doing this if it was going to harm them" well he see in twenty years time if it was a good idea, it is the degreasers that are the problem, they destroy the portective waxy coating on the leaves and roots.
I thought they had to have waste facilities to qualify as a CL. Is this not so?That's not easy on a cl where there isn't one.
The minimum requirements are drinking water, chemical waste disposal and dry rubbish disposal. No mention of grey water on CAMC web site that I can see. One or two we have visited have drive over grey water disposal but not many. Those on main drainage may not mind it going in the chemical dump but most of those with cess pits and septic tanks would rather it went anywhere but in there. More than once we have been asked to specifically water fruit trees or newly planted hedges with our grey water.I thought they had to have waste facilities to qualify as a CL. Is this not so?
On a CS now , grey water into the hedge. Some CLs and CSs have a specific drain for grey waste which with a van can be a bit of a pain if you can’t get close enough to put a pipe across. The vast majority we visit put it in the hedge. I prefer to attach our pipes and leave connected except when we take the van out, so we get a gradual drain rather tha a lot at once. But CLs and CSs must have fresh drinkable water and elsan point.The minimum requirements are drinking water, chemical waste disposal and dry rubbish disposal. No mention of grey water on CAMC web site that I can see. One or two we have visited have drive over grey water disposal but not many. Those on main drainage may not mind it going in the chemical dump but most of those with cess pits and septic tanks would rather it went anywhere but in there. More than once we have been asked to specifically water fruit trees or newly planted hedges with our grey water.
Yes slugs are tea drinkers.At home our coffee grounds always dumped in a flower bed apparently its great for the plants and also discourages slugs.
Our slugs are beer drinkersYes slugs are tea drinkers.![]()
