Grey water disposal filter
Blackburn, Aberdeenshire, UK
Romahome R30
Since 2022
Re:an advert seen in Camping and Caravanning Magazine May 2023.
The essence is that you drain your grey water through a filter direct into the ground (not onto the ground). I'm not convinced, and would sites allow it? Anybody tried one?
I don't really understand it, their website is very lacking on any detail or decent images. Does the water drain into the ground through the tiny legs? How is it any different to popping a sieve into a funnel and jabbing that into the ground? At least that would be easier to clean the "filter". What happens if the ground is already reasonably saturated, I would imagine having a shower it would soon back up, unless it's just spraying it onto the ground.
As far as I can see the filter is purely mechanical so takes out the bits and that’s all.
Fine if it’s going to a hedgerow but not sure sites will want the residue directly onto pitch.
It's £29.99 :LOL: :LOL: :LOL: :LOL:
Geoff
Like nickq I would have to question your "into not onto" statement.?
Saw an old boy at the Malvern show last year had made one from grey plastic drain pipe. Worked a treat but you will still get someone having a moan about it.
The old trick of a punctured carrier bag stuffed with grass cuttings would do just as well and no cost.
We have used that technique a few times and it seems to work OK.
I suppose it depends where your sited in a field, near the hedge rows is probably OK but not if your in the middle of a field .
No filters required and environmentally better than combining it with black waste that then overflows and pollutes our rivers and beaches. Water is best soaked into the land where it can do some good.
My vans got wheels & an engine I just drive to the dump point, far easier.
Dump point would need to be a "long" way off to get your engine up to operating temp to stop it getting gunked up... you dont after all want to idle it cold, or do you go for a drive and then to the dump 😂😂
Rarely stay more than one or two nights anywhere so dump in the way out or in. Also can do 6 days without needing to empty
Phew stinky :ROFLMAO: :ROFLMAO:
I guess it also only works if you can get a watertight seal on your outlet?
Does it just sprinkle on the ground? Or is water flowing into the ground through those tiny legs?
My family returns to a site every year. It's only really set up for tents, so it doesn't have a dumping point for grey. I end up driving the van close to the toilet block and using a pipe to empty into a grate from the showers. Or making the long walk many times with a bucket.
The hedge is fine for shower waste in limited quantities. Not fine for washing up water. Food waste attracts rodents.
No hedges?
I have even been on a full C&CC site where they said please use the hedges. They often have to pay to have their waste tanks emptied. My grey waste has very little food debris in it, I clean it off before washing up. Used grey water is best recycled through the ground.
i use paper towel to collect debris from plates. I try to get as little as possible into grey waste. If there is a particularly mucky tin can to recycle or things like coffee grounds that are too wet to put into waste bin, they go in the toilet to the cassette.
If on site for a few days, a collapsible bucket is useful to either chuck in hedge or down drain depending on owner’s wishes.
I enquired with the Camping and Caravan club (who are advertising the device in the ads section) and they came back with not allowed on club sites but CS May find them acceptable.
I have not bothered about them, I asked the manufacturer if they were acceptable to the club sites to use and they never bothered replying.
