Gas on/off on the ferry?
They are actually written for the refilling of domestic propane & butane bottles but apply to any vehicle transporting lpg.
A maximum of 2 cylinders is allowed with a maximum weight of 15 kgs per cylinder & can only be transported in an upright position & securely fixed.
So as I said if you come off the boat with 3 cylinders you are illegal straightaway, regardless of weight . Technically if you have 2 x refillables cylinders & carry seperate bottle that should be classed as 3 cylinders.
An underslung bulk tank does not come in to it as spanish regulations would assume that it was installed correctly & certificated as a spanish vehicles would be..here are links.
https://www.citizensadvice.org.es/faq/is-it-illegal-to-transport-gas-bottles-in-private-vehicle/
& N332;
https://n332.es/carrying-gas-canisters/
You will also note that they both mention that it is illegal to park in an underground car park,which i didn't bother mentioning as most motorhomes & pvc's are too big to do so, but anyone with a low roof camper van should be aware they must park above ground.
Very informative 😀
& N332;
I'm fairly certain those rules don't really apply to exchangeable or refillable gas cylinders actually installed / connected on MH's. For example a MH with a large underslung tank plus two installed / connected 11 kg cylinders.
Interesting.
Although I have just two 11kg Alugas bottles, I also carry a few of the flyspray sized gas canisters for our single ring for outside use. Wonder if that counts.
i doubt they would be a problem unless you have a large amount rolling about.:LOL:
I doubt that you would have a problem unless like my mate you have 3 cylinders in addition to 2 x 11kg refillables.If the Trafico on the side of the road says they do that is the end of it. You will have to pay the fine then appeal it.
Actually a lot of deodorant type aerosols use butane as a propellant so those little gas cans aren't a lot different. Very useful to cook a curry outside without the aroma lingering for days. I don't carry loads of little canisters, because although they don't last long they are universally obtainable.
Someone one here, maybe lennyhb, has a little gas barbecue that runs on them.
Yep BBQ is good, I carry 4 or 5 of cans in the gas locker, one thing that's cheaper in the UK.
It's car ones that burn, LiFePO4 used in Motorhomes are very safe and don't burn or explode.
Maybe this was one ?
Just boarded at Santander a not a word about turning our lpg off. I did as usual but I wasn’t asked too.
