- Jul 28, 2010
- 15,475
- 20,765
- Rapido 7090F 3 litre 160
- May 2010
It is still under warranty and the new circuit board they fitted last year never fully cured it.
The later model is 50 volts Peter
Yes 37 volts closed circuit not 33 as you quoted.
A pair of panels in series will be around 44 volts open circuit well inside the 50 volts
"Two panels in series on a good day will put out 18V each = 36V"
I think our first is the earlier one with four battery types and no backlight. The second has the backlight and five battery types.
Last October's pair are the very latest with a pulsing float voltage.
Peter
http://www.motorhomefun.co.uk/forum/threads/mppsolar-mppt-regulator-parallel-or-series.106170/I have just connected a pair of panels to a 200 watt controller to one battery with a constant 47watt load (cool box)
Either in series or parallel the power output is exactly the same under the same sky only a few minutes apart. I tried with one panel covered in each case and no shading effect occurred only a reduction of 50%
I will post a new thread with pictures later. I would like to try it under a grey sky as this is where a series connection is meant to have the advantage.
Either way this controller accepts series configuration without issue.
EDIT
The solar has rapidly overtaken the load so with panels covered I will endeavour to bring the battery voltage down for a test later.
Hello, I didn't know you were on here too![]()
