It's a Fogstar Drift I think, so should be heated when charging at low temperatures?Yes, low temperature cut off charging.
If its heated and the charging amps are too low, not enough for the heat pad, then it will NOT charge.It's a Fogstar Drift I think, so should be heated when charging at low temperatures?
Crikey am I glad I built my own LFP I measured the capacity of each cell, top balanced the cells in parallel with the same discharge/charger that the manufacturers use. I also used J-K bms that it is possible to set virtually every parameter know to mankind. I have always used a shunt to determine a SoC, but I tried a number of different shunts, including Votronic, Victron and a couple of cheap Chinese shunts and after a few cycles there was next to no difference between any of them. However, the Victron has the highest max current.Glad you're sorted.
Doing that would add to the cost for the consumer, how hard is it for a customer to charge a new battery to 100% at install? Re capacity, my battery was sold to me as rated at 230ah, as long as it meets that claim i'm happy, the fact that it appears to hold 243ah is a bonus.I do believe that suppliers such as Fogstar should top balance the cells, determine the battery capacity and provide clarification of this and then discharge to their shipment level
Few things to take on board if you like.Crikey am I glad I built my own LFP I measured the capacity of each cell, top balanced the cells in parallel with the same discharge/charger that the manufacturers use. I also used J-K bms that it is possible to set virtually every parameter know to mankind. I have always used a shunt to determine a SoC, but I tried a number of different shunts, including Votronic, Victron and a couple of cheap Chinese shunts and after a few cycles there was next to no difference between any of them. However, the Victron has the highest max current.
Now operational I have the balance turned off and after 3 months of use the cell voltage delta is never greater than 3-5 mV. I would echo that in a real environment the bms shunt is not as accurate as an external Coulomb counter and use the Votronic shunt for SoC. However, on the J-K bms it is possible to calibrate both V and current draw.
I do believe that suppliers such as Fogstar should top balance the cells, determine the battery capacity and provide clarification of this and then discharge to their shipment level. Folks can at least know what they have. All top quality new generation cells will deliver.
