Thought it was too good to be true that the BBC app listings were added to the EPG, now the wait for a fix
TVs usually can't have a VPN installed, so good luck using a smart TV for iplayer in France.Always confused about the Firestick ie why have one ? If your TV is a smart TV I presume you don't need one ??
5 isn't show available on the epg at all if you have deleted the 5 app and reinstalled as amazon advise. So you end up worse off.Hi, if you have the live tv just before you get to your channels, click on that then drop down to guide and access 5 from there - it comes up with no listing information but takes you straight onto 5
Better still look for Troypoint and download Kodi onto your FS![]()
You can ask a Firestick to find programs and better for touring with.Always confused about the Firestick ie why have one ? If your TV is a smart TV I presume you don't need one ??
FireStick’s are great I have one mainly for USA sports via VPN but also recommend Apple TV box. Much more expensive but you can get SKY GO and watch all sky channels if you have Sky account. Only been available since 2024. Not available on FirestickThanks that's very interesting, we have Nord VPN and was hoping to watch Netflix/ Sky Go on our forthcoming 3 month European trip on our new Cello C1924WS TV. However from what you've said that probably wouldn't work and we'd need to have a Firestick connected?
Hi, I'm not very up on these things but if I have a VPN on my router from which my TV is connected by WiFi won't that enable me to watch UK TV ? ThanksTVs usually can't have a VPN installed, so good luck using a smart TV for iplayer in France.
We completely ignore the smartness built into our TV, as the firestick works faster and better, and also does a higher quality stream (and we can control how much data it uses easier than the inbuilt TV apps).
My personal view is you will overpay for UK based sim if you want to use a smart-tv in France, where if you have a firestick you can connect to campsite wifi (or aire wifi) if it exists and use the vpn and still get UK tv just fine.
Hi, I have Sky Go, won't I be able to watch via VPN on my router ? ThanksFireStick’s are great I have one mainly for USA sports via VPN but also recommend Apple TV box. Much more expensive but you can get SKY GO and watch all sky channels if you have Sky account. Only been available since 2024. Not available on Firestick
Yes, you can -> but you won't be able to change region as trivially -> router vpn's are usually limited to one region, where you can swtich region in case of blocking in literally 2 seconds on ExpressVPN at least on a firestick. Doing so on a router requires logging into the router, changing settings from a page from your vpn provider, taking at least 5 minutes if not 10 with my slow reading! ExpressVPN has at least 6 UK endpoints at moment, so if iplayer if blocked from one you can change to another in seconds.Hi, I'm not very up on these things but if I have a VPN on my router from which my TV is connected by WiFi won't that enable me to watch UK TV ? Thanks
It's easier to say just install NordVPN's app on your firestick and try it, you'll likely see a dialog where you can set individual apps to use different regions. Your VPN on your router could be coming out in England, but your firestick could be coming out in Australia, both at same time, so you could then wtach an embargo'ed sports game thats not available in England via the stick whilst everything else on wifi is on England.Thanks for the detailed response which is very helpful. The bit I don't get is the Firestick connects over wifi to my router in the van - which has Nord VPN installed. So the download comes through the router via Nord VPN, I don't understand how another VPN in the Firestick thetefore works ?? The Firestick doesn't connect directly to the Internet, only through my router. Sorry, as you can see I'm really not very versed in these matters.....
As per above I have a VPN on each device I have, rather then on the router, this gives more flexibility. I use Surfshark now, although I previously used Nord, I moved away from them because of their pricing policy.Easiest just to do, and why many of us (me included) use VPN's on the stick is it's a ton easier to manage than on the router. Expressvpn takes around 2 seconds to change from being in England to being in Australia.
Thanks a lot, you've convinced me to get a Firestick - only £24 on Amazon atIt's easier to say just install NordVPN's app on your firestick and try it, you'll likely see a dialog where you can set individual apps to use different regions. Your VPN on your router could be coming out in England, but your firestick could be coming out in Australia, both at same time, so you could then wtach an embargo'ed sports game thats not available in England via the stick whilst everything else on wifi is on England.
Easiest just to do, and why many of us (me included) use VPN's on the stick is it's a ton easier to manage than on the router. Expressvpn takes around 2 seconds to change from being in England to being in Australia (or Poland, or Swizerand etc).
Thanks a lot, you've convinced me to get a Firestick - only £24 at Amazon at the moment. Last question I promise.....how is it powered, is it just through the TV itself ?It's easier to say just install NordVPN's app on your firestick and try it, you'll likely see a dialog where you can set individual apps to use different regions. Your VPN on your router could be coming out in England, but your firestick could be coming out in Australia, both at same time, so you could then wtach an embargo'ed sports game thats not available in England via the stick whilst everything else on wifi is on England.
We have smart tv in our hymer. Firestick works a lot better than inbuilt 'smart' features on tv.In theory you don't, except the fire stick seems to work better than my Panasonic smart tv and there are sometimes issues installing apps on the TV and fire stick, so neither are a problem free![]()
Redbull tv is also not loading on the epg. So it's down to amazon.I think I understand what is causing this issue but I think it's a bug. If you go to settings, Live TV then sync sources you will see My5, what should happen if you click on it, is it should come up with a list of all the available channels in My5, however there is no longer a My5 app it is now just called 5, so clicking on My5 does nothing, there is no My5 for the system to scan. Either 5 or Amazon need to sort this out.
