Fiat Ducato Particulate Matter Sensor
Jul 11, 2020
566
1,490
Southampton
Benimar Tessoro T486
Since August 2020
So, there are none anywhere in the world according to repairers and mh dealers in the uK.
Adams Morey have a back order for 5 (I'm number 5), Travelworld where I bought the MH have a back order of 30 or 40 dating back to end of last year, Lowdhams havent any either and no-one seems to be able to get one.
Fiat Italy are forwarding my enquiry to their international parts expeditor (not holding my breath).
My problem is that while "it is safe to drive" even though the engine light is on and the start/stop isnt working, what happens if:
1. The particulate matters become a problem but because the sensor isnt working, I won;t know about it
2. There's another different engine fault and because the EMS light is already on, I think it s still the PMS problem and won't know until the engine blows up/siezes creating an expensive repair that I might be liable for because I may have breached the warranty in some way
Grrrrrrr:(
Seems to only be 2 options. Either sit tight until the part becomes available or get aboard and get out and about, maybe travel & staylocal/UK only
Why not just have the codes read at the dealer. Might be. A bit expensive but at least you have piece of mind.
already diagnosed by Adams Morey so I know that *right now" there is no engine fault, other than the sensor. Concern is that something additional might occur unnoticed
I had the engine light come on on my 2021 Ducato (Manual, AdBlu, no stop-start). I read the code on a £10 Bluetooth dongle and the free Torque app. Code was P24D1 which indicated a Particulate Sensor fault. Booked it into my nearest Fiat Professional workshop who were unconcerned about continuing to drive it. I had no loss of power, and the only other symptom was loss of the "change gear" indicator on the dash.
Took 10 minutes to change the sensor and all been well ever since.
Upvote 1
I'd be tempted to fit a generic one short term to get piece of mind, but would be worried that Fiat would try to use it against you further down the line ?
There are genuine Fiat ones on there aswell if this is the part they're talking about:
Its a particulate matter sensor that I need but OEM does not necessarily mean made by the vehicle manufacturer as per this definition
OEM. Original Equipment Manufacturer (OEM) parts are built by the company that initially made the parts for the auto manufacturer. The OEM parts we carry are precisely the same as the part that came with your car. The difference is that it doesn’t carry the manufacturer’s logo. OEM parts are just as reliable as genuine parts, but you get them for a better value.
Better news today - had a call from Fiat in Milan they have an ETA for the parts of 3 weeks - whether that means in Italy and then have to be exported, I don't know
I've still never had an OEM part fail in well over 40 years of fitting them tbh
Eeek, no parts :(
Ours threw up the start/stop error and warning light the other day. Stopped at a level crossing and turned off while waiting for the train and got the error when restarting. We have error code 'P24AE' which is particulate matter sensor open circuit, and the van is due to go in to the dealer for checks in a week or so. Not so good if the part is unavailble though.
cheers,
Robin
Grrrrrrr:(
Hi all, newbie Karen here and also 😭😭😭. We have just gone through the same process as you KRO and are completely stumped (as well as facing a cancelled holiday if we can’t sort this). My Fiat dealer says they can’t even get a slot on the back order so it isn’t looking good. We are also reluctant (as newbies) to get an one part fitted as the dealer has said they will void the warranty if we do so....
Can I ask how you managed to contact Fiat direct? I want to make sure we are able to at least get ‘on the list’ for a part when it does come available and my dealer is being distinctly unhelpful about next steps... Thanks so much for any help you can offer.
I was asked by my dealer to contact Fiat Assist and the call was answered by an excellent english speaking Albanian lady who knew all about my parts order
Apparently by calling Fiat Assist it somehow escalates the order up the ladder, not sure how or why but hopefully it does the trick
Al
Grrrrrrr:(
My particulate matter failed after two weeks , Jordan’s in hull replaced it straight away but did state the MH needs to be used regularly or they fail.
Thank you so much for the responses all. I am going to try those avenues and see where I get to. I really appreciate the help. I’ll feedback any luck... K
Al
Hi Al - escalation sounds excellent! As I am a newbie and inexperienced in matters Fiat-ish, can you point me at a number for Fiat Assist? When I google it, I just get linked back to the main fiat customer care site. Is that right? I’m hoping to get through to the same lady you did (fingers crossed!).
I'm sure they're just as good but if it hasnt got a fiat logo on it, it's not fiat and so running a risk of a warranty void
Even with a fiat logo on it it still ain't a fiat. fiat don't make sensors or ecu's or brake pads. There are some on ebay in the genuine fiat box, one from Coastal motor homes ,a fiat professional dealer regularly reccomended. Note they are at Fiat prices not chinese prices.
it was just this one that I dialled
00800 3428 0000
but I was also given my Vantive case no. to quote as well, and my chassis no.
Al 👍
try google for FIAT camper assist. there will be either a contact number or perhaps on line chat that can give you a steer.
used them some time ago with good effect.
worth a look.
Thanks so much to Al and Phill - now found Fiat Camper Assist (was just googling Fiat Assist) and we‘ll give it a good go when the lines open tomorrow. Perhaps it’s just me but I would have thought my registered dealer could have had a go at that too - sigh...
Wish us luck all - 4 days before we have to cancel the holiday road trip...
K
No problem
I may be wrong but afaik the lines are open 24/7/365
give them a go the sooner the better
good luck
Al 👍
I have had a similar problem with my Citroen Relay, light on, sensor showing low voltag, garage wasn’t too fussed, but after 800 miles of mixed driving the light has gone out and engine is running fine, fingers crossed 🫣
Not sure if everyone is now sorted and the supply of replacement sensors has eased but our late 2021 ducato recently had this fault at exactly 2000 Miles along with the engine warning light etc. Went in for diagnosis on 6th July and a new PM sensor arrived and was fitted today. Mechanic said they are having to fit a lot of these.
