Electrical Issues with Hobby T500: Seeking Solutions (1 Viewer)
Apr 1, 2024
87
89
Bolton
Hobby T500 LHD
Spring 2024
There I was enjoying a nice cold cider and surfacing the Net with the the blinds closed ready for bed on a site in Fishguard when the lights went out. Anyway I carried on surfing and enjoying the cider before investigating the problem.
Needless to say it is raining and my only torch turned out to have flat batteries!
Symptoms:
All lighting is out even though running through two different fuses.
Mains sockets were working (Kettle could be boiled and PC being charged. So unless by some bizarre means the van has an inverter I did not know about I still had partial mains power)
Checked the trip switches in the garage. Both OK.
Checked the 20 amp fused - Both OK
Checked the EHU at the site post - No sign of problems there
Then I noticed that the switch on the Panel over the door was out. Pressing that restored the lights. Magic! Problem solved - NOT!!!. The lights are now tripping out every few minutes but I still have 13 amp/240 volt power
I have turned off most of the lights but still it is tripping out and I appear to have lost my Truma (gas only) when tripped out.
So it is a problem apparently affecting 12V only. In the morning I will disconnect the EHU and see if the lights will work off the auxiliary battery. I will also set the fridge to run on gas to see if that sorts things.
Any suggestions as to the nature of the problem and a solution?
As I say there is penetrating drizzly rain atm.
I have swapped EHU connections but that makes no difference.
Currently (No pun intended!) when I press to reset the button top right in the photo the led alongside flashes before tripping out again a few minutes later.
Tomorrow is a dry day. Fingers crossed the problem will then go away and I can certainly dry off the EHU plug and socket.
I am on this site one more night (and can get torch batteries tomorrow) but I am on my way to France in 3 weeks and need this sorting by then!!
All advice appreciated! Currently I am completely in the dark (That pun was intended!)
Chris
Jan 2, 2024
672
890
Lincolnshire, UK
Peugeot boxer
Bad idea ! Maybe take a look at eBay lots of big sellers and sometimes Tayna are cheaper on eBay than their own website And yes 2 X 110ah will go in you will need 1 X lead + both ends 1 lead - both ends
PlacidoD
Apr 1, 2024
87
89
Bolton
Hobby T500 LHD
Spring 2024
Back to the drawing board! Further reading reveals EFB batteries apparently require a special charger!!!
Chris
672
890
Lincolnshire, UK
Peugeot boxer
Personally as a temporary (1to4 yrs) I would buy 2 cheapish flooded la batteries @110ah and a meter of 25 mm battery lead 2+ 2 - clamps circa £220.
With a view to going lithium in the future
Quick relatively cheap easy ... plenty of time to assess future needs
PlacidoD
Apr 1, 2024
87
89
Bolton
Hobby T500 LHD
Spring 2024
Ideally non lithium bats SHOULD be as near to identical as possible in simple terms the greater the difference the less benefit and or shorter the life
Thanks that is what I thought.
My problem is time to get this done either my own or finding a mobile fitter that can sort this for me.
My leisure battery will need to be low profile (190mm) and either 315mm or perhaps 345/355 mm which limits the Ah to maybe 95Ah.
My plan:
1. Acquire a multi-meter today and check the existing battery (Was I just asking too much of it being unaware of its limitations. I can easily limit output via lighting/ Is it good enough at least for my first short trip to France?)
2. Now or in the near future acquire one circa 95 Ah leisure wet battery.
3. Post my short trip to France acquire either a 2nd identical battery or buy two at the same time and thus double my capacity.
I suppose I could buy two now but fit only one and the 2nd if I have time to source leads etc. I have 12v chargers to keep a 2nd charger in good condition pending a fit.
Let me see what the multi-meter shows today.
Chris
MichaelT
3,353
6,619
Colchester
Carthago I 143 LE
Since 2016
My plan:
Chris
If you do fit 2 take the positive from one battery the negative from the other.
672
890
Lincolnshire, UK
Peugeot boxer
My plan:
Chris
Thought 190mm sounded familiar,I have a rough sketch of my seat base with apx measurments(done for obtaining lithium) Just had a look and It shows seatbox 190 high so my 2x 110ah must be no more than 190...I seem to remember having a few sellers to choose from so by no means rare... I'll measure them later and see if I can find out where I bought them (doubtful)
672
890
Lincolnshire, UK
Peugeot boxer
Just had a look for my invoice sorry can't find it.But a.quick Google Tayna. Powerline XV110
Circa £85 Inc delivery Dual purpose leisure battery 4 year G.tee. 2 will go under my seat and should yours.(Powerline is Tayna own brand.
1,601
1,524
Swift Suntor 590RL
I've used low profile, 175mm high, 110AH batteries for years in my boat, my previous PVC, my present motorhome before I switched to Lifepo4 and I fitted 2 to my sisters motorhome earlier this year.
About £80 delivered from Ebay.
Normally change them every 4 years'ish.
7,071
8,305
Manchester
A class Hymer
Since the 80s
Don't expect much information on the battery state of health just from a meter reading. You could measure the 'resting voltage' of the battery (not being charged, not powering a load, resting for an hour or two at least). That is a reasonable indication of the state of charge of the battery, from 0% to 100%. There are battery voltage charts on the internet, slightly different for the different types of batteries.
But what you want to know is the state of health, ie does 100% charge mean 110Ah, or has the battery capacity deteriorated so that even when 100% full the '110Ah' battery is only holding say 80Ah of charge. That is more difficult to measure.
The basic idea is: charge up to 100%. Take out a known amount of charge, maybe about 20% of the label capacity. Measure the resting voltage to see what % state of charge it has dropped to. Then calculate how much below expectations it is.
For example, for a 95Ah battery, 20% is 19Ah. So that could be say 5 amps for 3.8 hours, ie 3 hr 48 min. Then measure the voltage. If the resting voltage chart says 80% then the battery is perfect. If it says 70% it has deteriorated, but probably still OK. If it says 50% or lower, then the battery is on its way out.
As far as I know there is no short-cut for this measurement. The 'battery tester' devices used by garages will test the starter battery capacity - the ability to provide a massive current (hundreds of amps) for a few seconds, to power a starter motor. Leisure batteries typically provide a small current, say 5 amps, for many hours. Many proper leisure batteries, especially Gels, might be damaged by the starter battery testing device.
How do you load the battery with say 5 amps? An easy way it to use the fact that for a 12 volt battery, each amp carries 12 watts. So if you turn on 60 watts of load that will draw 5 amps from the battery. The only advantage of those non-LED filament lamps you have is that they are useful for loading a battery for testing. Six 10W lamps is fine.
Actually measuring the amps with a multimeter is possible in theory, but is a lot of faff, because you have to disconnect the wire and put the meter into the circuit so that the amps flows through the meter. Nowadays I always use a clamp meter, which just clips round the wire and measures the amps by measuring the magnetic field that the amps generates - no disconnection necessary.
I have one of these:
Be careful if you are thinking of buying a clamp meter. Most of them, including the cheaper ones in DIY stores, will only measure AC amps. Even though the box label says 'AC/DC Clamp Meter'. They measure DC Volts but not DC Amps. Read the small print in the spec sheet. They are bought by house electricians for working on AC mains.
672
890
Lincolnshire, UK
Peugeot boxer
But what you want to know is the state of health, ie does 100% charge mean 110Ah, or has the battery capacity deteriorated so that even when 100% full it is only holding say 80Ah of charge. That is more difficult to measure.
For example, for a 95Ah battery, 20% is 19Ah. So that could be say 5 amps for 3.8 hours, ie 3 hr 48 min. If the resting voltage chart says 80% then the battery is perfect. If it says 70% it has deteriorated, but probably still OK. If it says 50% or lower, then the battery is on its way out.
Nice explanation on all counts
PlacidoD
Apr 1, 2024
87
89
Bolton
Hobby T500 LHD
Spring 2024
My problem is length. I am not sure that a 345 or 354mm length will fit under my driver's seat. Current length is 315mm. Something like 335mm would definitely fit but above that a bigger battery is likely to foul something. Obviously the extra length would make it easy to get to 110Ah.
Chris
PlacidoD
Apr 1, 2024
87
89
Bolton
Hobby T500 LHD
Spring 2024
Thanks for taking so much trouble to educate me!!
I much prefer to do things myself. That way I know if I am being told tall stories about complexity and cost if beyond my competence or simply do not have the time when instructing others. And anyway, sods law, things will always go wrong when you are in a country whose language you do not speak. So an ability to self help makes sense!
Chris
PlacidoD
Apr 1, 2024
87
89
Bolton
Hobby T500 LHD
Spring 2024
That may well be too big for my box which narrows on three out of four sides towards the base. (So the footprint for the base of the battery is much narrower than the topside on three sides.)
This one is an exact match for the dimensions of the existing battery:
Thanks for the info that powerline is the own brand for Tayna. I have been using Tayna for in excess of 10 years and have always found them very reliable.
Chris
1,601
1,524
Swift Suntor 590RL
Chris
The battery I'm referring to is 110AH, L315mm x W175mm x H175mm (including terminal posts).
Ebay item no 325864748918. £86 delivered.
I know it's only got a 2 year warranty but after having used them for years I've always got 4 years out of them at least.
715
658
Pilote P732 2011
3rd Time around, since 2000
Goid spot for size. Be worth PlacidoD concudering two of these. Bet that ebay selker does leads to or amazon for next day delivery. You might as well get it done while seat is off or you doing it all over again another day.
