There I was enjoying a nice cold cider and surfacing the Net with the the blinds closed ready for bed on a site in Fishguard when the lights went out. Anyway I carried on surfing and enjoying the cider before investigating the problem.
Needless to say it is raining and my only torch turned out to have flat batteries!
Symptoms:
All lighting is out even though running through two different fuses.
Mains sockets were working (Kettle could be boiled and PC being charged. So unless by some bizarre means the van has an inverter I did not know about I still had partial mains power)
Checked the trip switches in the garage. Both OK.
Checked the 20 amp fused - Both OK
Checked the EHU at the site post - No sign of problems there
Then I noticed that the switch on the Panel over the door was out. Pressing that restored the lights. Magic! Problem solved - NOT!!!. The lights are now tripping out every few minutes but I still have 13 amp/240 volt power
I have turned off most of the lights but still it is tripping out and I appear to have lost my Truma (gas only) when tripped out.
So it is a problem apparently affecting 12V only. In the morning I will disconnect the EHU and see if the lights will work off the auxiliary battery. I will also set the fridge to run on gas to see if that sorts things.
Any suggestions as to the nature of the problem and a solution?
As I say there is penetrating drizzly rain atm.
I have swapped EHU connections but that makes no difference.
Currently (No pun intended!) when I press to reset the button top right in the photo the led alongside flashes before tripping out again a few minutes later.
Tomorrow is a dry day. Fingers crossed the problem will then go away and I can certainly dry off the EHU plug and socket.
I am on this site one more night (and can get torch batteries tomorrow) but I am on my way to France in 3 weeks and need this sorting by then!!
All advice appreciated! Currently I am completely in the dark (That pun was intended!)
Chris
Symptoms:
Chris
