Could you possibly guide me how to access the spindle should I remove the plastic covers as in picture.More than likely dirt or seized spindle use a dry ptfe type of lube spray not oil or grease![]()
Thanks I will have a look.On my step there is a plasic cover on the underside of the step which is reasonably easy to remove. You may be able to see what is going on if you remove it.
Can I borrow your block of wood please?Thanks for all the replies. I managed to get it working with a couple of bumps with a block of wood. I could hear the rough sound of grit on the left side runners only stuff I had at hand was silicone spray which has helped a lot. I will get ptfe tomorrow .
Thanks to all for their wisdom.View attachment 520477
Strip it down and clean the runners then lubeThanks for all the replies. I managed to get it working with a couple of bumps with a block of wood. I could hear the rough sound of grit on the left side runners only stuff I had at hand was silicone spray which has helped a lot. I will get ptfe tomorrow .
Thanks tomorrow after I get the lube.Strip it down and clean the runners then lube![]()
You gave me the ideaLike Howard B I have made my Thule step a manual pull out one. They are always going wrong and disconnecting the two arms after taking the underside plate off was easy. It works lik clockwork now it’s manually operated.
Phil
