Has anyone fitted an electric step to the front passenger door as my good lady who is neither a high jump champion or an Amazon and finds the step up and down even worse? Any sensible suggestions besides stilts please?
I had one fitted to the passenger door for the same reason after getting up and down at toll booths across France a few years ago. I can't remember cost etc. I will ask Steve and get back to you laterHas anyone fitted an electric step to the front passenger door as my good lady who is neither a high jump champion or an Amazon and finds the step up and down even worse? Any sensible suggestions besides stilts please?
Thanks very much, look forward to your info.I had one fitted to the passenger door for the same reason after getting up and down at toll booths across France a few years ago. I can't remember cost etc. I will ask Steve and get back to you later
Steve says we got it from Mick at S.A.P. and that he is in reviews on here. He can't remember the cost and neither can I, it was about 5 years ago. It can't have been really expensive as we would both remember that!!! I'll see if I can find an invoice for it.Thanks very much, look forward to your info.
Ok, I can try SAP but thanks for offering to hunt for an invoice.Steve says we got it from Mick at S.A.P. and that he is in reviews on here. He can't remember the cost and neither can I, it was about 5 years ago. It can't have been really expensive as we would both remember that!!! I'll see if I can find an invoice for it.
Sorry, had a good look but it's not on my filing system it must be up in the loft with our old accounts.Ok, I can try SAP but thanks for offering to hunt for an invoice.
Please dont worry but thanks for offering.Sorry, had a good look but it's not on my filing system it must be up in the loft with our old accounts.
Cheers Jim, thanks for that, will investigate !Quite easy on an A Class I have the factory option on my driver's door. Make sure you get a Thule step the Project 2000 that Hymer fit are rubbish. They are about £300 plus any fitting costs if not doing it yourself.
Thanks Lenny I was thinking we paid around 500 quid for ours. Edited to say it was about 5 years agoQuite easy on an A Class I have the factory option on my driver's door. Make sure you get a Thule step the Project 2000 that Hymer fit are rubbish. They are about £300 plus any fitting costs if not doing it yourself.
Jacksons have them at 312, it would be 2 or 3 hours to I would think as its not job anyone does often.Thanks Lenny I was thinking we paid around 500 quid for ours. Edited to say it was about 5 years ago
Hate to give out the wrong info. Just double checked and the passenger door step on our Frankie is a slide out the drop down is the hab door.Ours is the drop down one with an alarm if still down when ignition key is turned. I always get a tut for that!!! well it slides out then drops down.
I did wonder how they had managed to fit it.Hate to give out the wrong info. Just double checked and the passenger door step on our Frankie is a slide out the drop down is the hab door.
Yes it was your comment that made me double check LennyI did wonder how they had managed to fit it.
I don't like my slide out...too slow and doesn't drop down enough....much preferred the Thule slide and drop one I had on my prev vans.So, on recommendation the solution is a Thule slide out step. So far my best price is O’Learys at £249. Will check out any other possibles before pressing the go button.
Thanks for the info all.
Didn't think there was enough room under the drivers door to fit a dropdown one.I don't like my slide out...too slow and doesn't drop down enough....much preferred the Thule slide and drop one I had on my prev vans.
You have been lucky, as steps go the biggest pile of poo ever. Lost count of the number of times I've repaired mine and know quite a few others with similar problems.Mine has the Hymer fitted Project 2000 version. Van is now 10 year old and step still working perfectly.
Should fit, mines a factory fitted option.Update, as it wasn't raining too bad I decided to lie on my back and have a good look underneath where the step needs to go.
two immediate obstacles fuel filler pipe and exhaust pipe. I dont think there is enough clearance depth wise for the slide out one so will do closer more detailed survey. Looks doubtful to me.
