EGR valve blanking/cheating
Techno help please, I have disconnected egr on 2.5 Renault after continuous limp mode, now runs as normal. Anyone in Leeds area do re mapping or is their any other way of fooling ecu
Sorry I'm not familiar with that engine nor remappers.
I've had my ecu remapped to delete the egr function... its still in place but permanently shut and disconnected...
That's on a transit mk7...
Have a Google for van tuner... speak to Martin. .
Andy.
P's. . Don't think there is another way with electronically actuated egr valves if you want it blanked..
@Techno - so where can I read all about the custom exhaust?
But is the cat empty?
Hello,
I'm pretty new here but just wanted to say that I have just fitted the EGR blanking plate and TAFMET cheat box - seems to work perfectly. A rather fiddly job though to to my hands being too big!
I was sent down this route by needing to replace the throttle body and found both it and the inlet manifold really crapped up, so to make the throttle valve last longer and to stop my engine breathing in it's own dirty waste products, I went ahead and fitted the blanking kit.
No discernible change except much less smoke on cold start-up - I'm looking forward to increased reliability but I don't really expect anything else from the mod.
Mine is a 3.0 Iveco engine in a Fiat Burstner 747 (2007). Thankfully I don't have a DPF to worry about.
Just finished reading this whole thread , and wow...
Anyway I've now decided to add the task of blanking off the erg valve.
Ours is a 2007 Fiat 2.3 Ltr 130 Multi jet which has about 15k on the clock.
Once I install the blank of plate do I need to do anything else ? Like with the ecu ?
This is the correct part isn't it?
Also can anyone rec a cheap decent reader to read / reset any engine codes
Someone who has your van will be more help but as a guide...if you have an electronically activated egr valve as opposed to a mechanical then you may have issues if you just blank it off... they have feedback to the ecu and that can generate fault codes...
There has been talk that a small hole in the blanking plate copes with this problem but that solution is lost on me...
If you've read the thread you will know I had the function removed from the ecu by way of a remap . (On a mk7 transit )
On the code reader front have a Google. .. I'd prefer one that had some fiat software on in your case rather than just an obd 11 reader..
I got one from gendan that had the ability to read ford fault codes as well as the generic obd codes and was able to read Brake (abs )and the restraint system like air bag and seat belt codes... an obd will only do the power train module...
Hope that helps..
Andy.
Thanks Andy , I'm sure someone here that owns a 2.3 ltr 130hp multi jet is bound to of blanked of their erg valve.
Fiat Ducati 2.3 multijet reg 2010. 29,000 miles.
Eleven months ago (October 2016), I suffered major engine failure due to the auxiliary belt shredding and wrapping itself around the timing belt.
The engine has been rebuilt and the van returned to the repairer some 100 miles from me three times now and I have finally lost all faith in this garage.
The engine appears to run fine and I have no fault codes. After 1200 miles touring around France I estimate that I have consumed 12 Ltr of coolant. White/grey smoke could be seen exiting the exhaust after idling at the Toll gates and on occasion under load, black smoke. There is no evidence of emulsified oil in the engine.
Reading all the above I have a feeling it may be my EGR cooler/valve that is causing the problem? What do you guys think? Taking the van back to the repairer is not an option.
Cheers adgy
Cheers adgy
I am no expert but sounds like possibly a new head gasket required :(
Last year in Spain my 3.0 Fiat went into limp home mode, but being in the trade I turned the engine on and off 5 times which clears the fault but only for about 10 miles then it cuts in again. I managed to do this all the way home to UK, it was a bit hairy sometimes overtaking trucks.
Cheers adgy
Almost definitely the coolant is getting into the engine. If the rebuild involved a head skim, I would be worried that the head is scrap.
It seems that you need to find a good mechanic to diagnose what is happening and then see about trying to reclaim any remedial costs from the place that has failed on three occasions to solve it.
Agree, white smoke in the exhaust usally points towards a warped cylinder head or at the very least a blown head gasket. No point in replacing the gasket without checking the trueness of the head.
Just adding to what has been said really..
There may well be nothing wrong with your rebuild or head gasket...
It does sound like you may have an egr cooler leak.. if it's easy to get at and remove it should be possible to see the evidence if you can remove the valve and have a look when the engine is cool there may well be signs of damp on the sooty walls..
Andy.
Thanks for the quick replies.
Looks like my fingernails are going to get a bit grubby over the next couple of weeks.
I'll keep you posted.
By the way Ive ordered the blanking plate, Should I fit it when I strip the unit down?
Cheers adgy
Cheers adgy
https://www.reference.com/vehicles/diesel-engine-white-smoke-25ddb4978996a55a
Just found and read this thread from start to finish...great stuff!
I too would blank off the EGR but not sure if my van has one? its a 1999 2.8 Fiat Ducato idtd....any techies on here know if that engine has an egr?....
@Irishrover I’d say yes, but without seeing the vehicle I can’t say for sure. EGR systems for Diesel engined passenger vehicles, vans etc have been in production pre 1990’s. I had a 1991 2.0 diesel Montego estate fitted with the Prima Perkins Di engine, this had a vacuum egr system. Took me ten minutes to make and fit the banking plate. Sadly the body fell of the engine after 200k miles. I sold the engine & gearbox to a guy who fitted to a Maestro van. Excellent engine. Crap car producer.
Mine is a 2005 version that doesn't have one.
Further to my earlier post in this thread:
Cheers adgy
I bit the bullet on this one and after contacting the garage they agreed to repair the fault as per their warranty agreement.
This was after I bought a cheap block test kit from ebay which clearly showed exhaust gases were entering the coolant system and providing them with the evidence. Bearing in mind the first time I took it back to them they 'fobbed me off' with its just an injector fault.................. you dont really want to leave it with us for two or three weeks when you can drive it back home and get it fixed locally. Second time I returned it and left it with them for three weeks they gave me it back saying they had replaced the EGR valve.
Anyway whilst driving the 100 mile from 'our house' over the tops, ( I dont want to name and shame the garage just yet!) to the garage the Engine Management Light came on and crawling up The M62 at Max 35 mph in limp mode was a tad embarrasing.
Mentioned the EMl to the garage and left the van again. Three weeks later, a couple of days ago, I returned to the garage to find out that the cylinder head was cracked and they had replaced it.
Two fault codes were pointed out to me............ P0403 (EGR circuit malfunction) & P0638 (Throttle actuator control range, perform blank1). I was informed both of which were not the responsibility of the garage and had not been rectified. Needless to say I had to limp the van back over the top.
As Ive learnt quite alot about diesel engines over the last year and being mechanically minded I have decided to find the fault(s) and rectify them myself ( I love YouTube when it comes to gaining more knowledge), any way I have attached a number of photos of the strip down so far. May help others!
By the way am I looking in the right direction to find the fault? The valve assy looks OK to me.
Cheers adgy
Ever had that 'Eureka moment' and you you thought you were god's gift to diesel mechanics????????? Read on!
Today I managed to remove the EGR cooler and I have to bruises to prove it! (see below)
Hardest part was removing the bottom bolt on the EGR inlet manifold.
Now for that moment! Look carefully at the split in the EGR pipe just after the flange. BINGO I thought this is the problem, I have the cure!
I had initially bought a new EGR cooler assembly from Poland via ebay but unfortunately it dosn't fit, plan B fit the blanking plate.
Only problem now is the Engine Management Light (EML) is still illuminated with the same fault codes and the engine is still in limp mode Successfully deleted the codes using my OBD Check app but they return as soon as the ignition is the switched back on.
Any ideas?
I have a 2007 Relay with 2.2 Tranny engine.Fitted recon motor and old manifold was completely blocked.Blanked EGR off first with plate with hole in then without hole.EML on both times. Got it re-programmed as had 2 new injectors -no light now. Van runs smoother /cleaner/more economical so still better for enviroment.
ERG valve issues aren't that common in the Ducato Iveco engine. It's the throttle body that screws up that causes the reported ERG fault. Unlike other engines, the Fiat doesn't coke up that much... it has other weaknesses instead.
i will need to get under the bonnet and have a shifty of where it is.
@Phill D did you ever fit an EGR blanking plate to your 2.3 130 multijet ducato ??
if so just wondered if you ever had any problem ? and if it was dead simple to fit ??
Long story, short, Saturday last the EMC came up on the Dash. Called out the RAC, the guy, took some readings :-
Diagnostic Codes
RAC DIAGNOSTIC SYSTEM
System Type: ENGINE
DTC: P0638,Throttle actuator control (TAC) , bank 1 - range/performance problem
System Type: ENGINE SYSTEM TEST/VALUES
Name: F1AE0481D - BOSCH EDC16C39 CF4 EOBD - 2.3L - 88 (120)
F1AE0481N - BOSCH EDC16C39 CF4 EOBD - 2.3L - 96 (131)
F1AE3481C - BOSCH EDC16C39 CF4 EOBD - 2.3L
F1AE3481D - MARELLI 8F3 CF5/EOBD - 2.3L - 96 (131)
F1AE3481E - DIAGNOSE - 2.3L - 109 (148)
F1AE3481G - BOSCH EDC16C39 CF4 EOBD - 2.3L - 81 (110)
F1AE3481G - DIAGNOSE - 2.0L - 81 (110)
DTC: P0530,AC pressure sensor
DTC: P0638,Throttle control valve
DTC: P0401,EGR valve
Ignore A/C pressure sensor code, its probably just needing some gas.
However, Throttle control valve and EGR, codes are a bit of a worry.
Having read the thread (not all of it) It would appear that at the very least a Physical clean may be required. Before I go down the road of ripping lumps of Engine off, on the driveway in the cold. Has anyone ever achieved success with "Engine Cleaners" i.e. Wynns etc?. Even if it just gets me into the new year and milder weather.
The RAC guy, deleted the codes, and E-Mailed me the printout, The EMC light is back on again, so it looks like it is not a "one off".
In my case (Ducato 2.3), the apparent EGR issues were caused by the failure of the throttle body. The EGR system was fine.
