3
33716
Thought as much, thanks for the quick reply Andy. Thinking of finishing the job completely now the weather is warmer
Larger bore pipe doesn't mean you will get better flow, if you have no DPF and Cat the thing to look at is the silencers, I have only one with baffles to give enough back pressure then the other 2 (yes 2 as I wanted the exhaust quieter than on a commercial) are Vortex Raceflo which use sound absorbant material around the outside rather than baffles that slow the gasses.Just spoke to my custom exhaust builder and he will do me a complete system all the way from the turbo with a dummy cat and bigger bore pipe with lifetime warranty for £380
Very unlikely at that age
It runs miles better blocked and my emission is only 0.02
I haven't a clue to what you're on aboutI forget the exact wording but if the chamber on / from the manifold gets blocked up to manually remove it they have to remove the manifold and all the bits that go with it, so does blocking it just remove the sensor problem but leaves the problem itself to get worse. I am not expert so can only relay my experiece.
Hi buttons the reading I've done suggests that the egr function is there to reduce the oxides of nitrogen from forming by effectively cooling the combustion process by introducing small amounts of exhaust gas.. I didn't think that it had an adverse effect on valves burning out etc by blanking it off... do you know that people who have blanked it off have had those sort of failures.I've not had the pleasure of reading this thread through so excuse my post if it is not relevant but
the exhaust gases being emitted by the engine back into the combustion chambers can have a cooling effect and helps to prevent exhaust valves from overheating, which can accelerate their wear and tear.
Im getting lost here lol...The EGR cooling unit is only circulated engine coolant (HOT) so it cannot reduce the temperature any lower than the intake air & fuel mix so adds nothing to the equation.
Nothing positive that is! but plenty of sh1te
