Northernraider
- Jul 30, 2017
- 33,249
- 236,797
- N&B Flair 8000ib
- AirOn and off since 95
I haven't changed anything on the braking system garry other than the pads , and the fluidExactly it’s your home, if your house roof leaks you get a roofing company to fix it, not some bloke who’s felted his shed…
It should only take a day to do it and you could book in somewhere but then that’s more money and probably difficult because of the dogs…
If you take it to a main dealer to change the master cylinder and it doesn’t improve then you have some recourse, they would have done many before, you’ve changed almost everything else on the braking system so it can only be the master cylinder…
Sometimes your just bloody stubborn and soldier on hoping something improves if it saves you a few bob but if you let it go on it will surely cost more in the long run and hopefully doesn’t hurt anyone else….
Which is exactly my point , this van has numerous boxes , valves and things I've never seen before connected to the braking system. At the moment it could be any one of those things hence
I'd rather keep the cost of a master cylinder replacement down at present because there is no guarantee its the cause .
I'm the one driving the van and the only one that can feel and see what it's doing .
It's not the first vehicle I've had brake faults with.
Yes there are some elements I haven't tackled or repaired before which is why I'm asking people but there are various replies and ideas from people some that are knowledgeable and some who may have the best intentions but are not in the least bit mechanically minded.
From the master cylinder I have 2 flexi hoses that go In to another large box mounted on chassis with electric connections and hydraulic pipework coming out of it. I've not seen one before. Then at the rear there are 2 boxes one either side connected to brakes and a valve on rear axle. Then there's a cylinder connected to the load sensing valve .
The brakes aren't simple on this .
I'm happy to have the master cylinder replaced by a reputable garage if it costs around £200. ....if its gonna cost more than that I want to know for sure its the definite problem.
I also don't want to be stuck without the van
I'm aware of the brake efficiency and I drive constantly with that in mind. I've driven 30 miles today and I've tested the van doing emergency stop etc and it stops ... on general roads its fine . I have only had an issue on very steep windy hills where I've the brake pedal pressed for a long period of time ...the brakes then get hot and are crap ..
When I had issue in the UK the pedal went to the floor . That did not happen the other day I had a firm pedal the brakes were just not stopping the van .
On the previous van I experienced brake fade in Greece on the mountains 3/4 times ... then the brakes returned when cold and worked fine . I never did get that fluid changed and it passed the mot brake test etc .
I will try iveco in Agadir and see what they say .
If I could have got a master cylinder before so I had the correct one here then I'd have tried a garage for fitting it and bleeding brakes.
I have enough issue just getting fuel in this bloody country never mind anything else.
