I guess that i' m a depends sort of person
Yes, funnily enoughHave you thought of just filling up to approx 70%?![]()
If fresh tank is full then waste would be empty and when waste is full then fresh would be almost empty, both never full at same time.
We will never all agree on anything,
On our mains supply 15 minutes would get you between 800 &900 litresbig it is but takes at least 15 minutes with a blasting hosepipe?
Yes, my Pilots had a central baffle, but I cannot see if the current van as since the only bit you can get to is the lid (if you are a contortionist) and the drain. As the tank is 3/4 of the width of the van then I assume it has them. The rather huge fuel tank under the chassis runs from just behind the engine all the way to the back axle. It has several sets of baffles moulded into itI've noticed that on many newer motorhomes the water tanks are now being fitted with baffles to equalise the water sloshing in the tank.
Only travel UK and carry 5Litre bottle for backup and about quarter tank of water - not sure how big it is but takes at least 15 minutes with a blasting hosepipe? If unsure where staying or access to water or arriving late/in dark then fill tank up at home.
I always brim when filling up, it allows me to (more) accurately monitor the fuel consumption, One of the first indications of "issues" is often an increase in consumption. One of the things you learn very early in Marine Environments. When you can be using up to 100tons a day!I never fill the fuel tank either. There's lots of fuel station so why carry 80litres around...just saying!
Aye, Arrive at Supposedly open campsite?. Gates locked, no water or anything, spend night out side gates, then have to find a Garage for water, before moving on. Many if not all, French garages turn off their water when the temperature falls. Many Aires too shut down the service point. Fortunately at that time we had 60US gallons of fresh, so for us it wasnt a big issue, but I would not transit France in winter without a full tank to start off.not in wintertime France anyway!
170 kg is 0.17 of a tonne not 1.7 tonnesNot sure I would want to travel with 170kg (1.7ish tons) added to my normal payload. Travelled recently with 1/2 tank of a water tank recently and the handling was quite different. Don’t most motorhomes come with a tap on the tank that has a quarter turn leaves 20 litres in the tank.
so have you got 170 litre water tank or are you adding fuel and water together there.
No if its a Hymer it will be around 120L.
If I owned a van where 60kg affected the handling I'd be selling it ASAP
People have posted in the past that there is a slight sway noticeable, when the tank is not either full or Empty. IMV it`s normally hardly noticeable. In theory it is a well known "effect" (Free Surface).How was it different?
Decimal point issue.... 0.17 of a tonne. My (continental) van has a drain tap - nothing else. I think you are referring to what some manufacturers do when they are considerably payload restricted (3500 kg, mostly).Not sure I would want to travel with 170kg (1.7ish tons) added to my normal payload. Travelled recently with 1/2 tank of a water tank recently and the handling was quite different. Don’t most motorhomes come with a tap on the tank that has a quarter turn leaves 20 litres in the tank.
Referring back to my trusty Derrett’s ship stability for mates and masters, you can calculate the effect of free surface. 3cm in the car deck is enough to capsize a ferry. Construction and door design changed as a result of the sad Herald tragedy. On our large refrigerated gas ships, there were very strict fill limits (<20% or >80%) as I recall for the same reasonPeople have posted in the past that there is a slight sway noticeable, when the tank is not either full or Empty. IMV it`s normally hardly noticeable. In theory it is a well known "effect" (Free Surface).
2 (non Motorhome) cases come to mind, Westons Cider? ( I think), had some bulk tank trucks built. The maker neglected to put baffles in the tank. First time out the driver had a part load. Stopped for the traffic lights he took his foot of the brake just as the load having been sloshing back and forth in the tank hit the front bulkhead causing the truck to roll forward and push a car into the crossing traffic.
The second was the Herald of Free Enterprise, where the water which gained access to the car deck created a wedge of water on the low side during the turn and was sufficient to capsize the Ferry.
How did you cure it?When I got this Elddis earlier in the month, I was leaving with full tanks and arriving with half full
Ive cured the overflow issue and now arrive full as well (100litres)
I sailed with a Chief Engineer, newly qualified, who had a "passion" for wanting "his" fuel tanks "pressed up". Until the fateful day when having exited the Suez into the Red Sea, within a day he had oil on the deck. The sea temp was 10deg above that of the Med, and the oil had expanded up the vent pipe and into the scuppers!. "Chippy" saved the day, blocking the scupper overside with Gunny Bags of Sand!. giving us time to lower the tank levels and the deck crew time to clean the deck before we got "nicked" for pollution.Referring back to my trusty Derrett’s ship stability for mates and masters, you can calculate the effect of free surface. 3cm in the car deck is enough to capsize a ferry. Construction and door design changed as a result of the sad Herald tragedy. On our large refrigerated gas ships, there were very strict fill limits (<20% or >80%) as I recall for the same reason
